Tricks to stop interior squeeks?
Old Jul 18, 2004 | 07:03 PM
BayRay's Avatar
BayRay
Default Tricks to stop interior squeeks?
The interior trim around my 65 Coupe's rear window squeeks from vibration. The trim screws are all tight but I notice some flex in the trim between screw heads. If I put my hand on the trim it stops making noise. I thought about putting some foam weatherstipping with the self adhesive backing on the back side of the trim. Anybody have any better ideas?
BayRay
Old Jul 18, 2004 | 08:28 PM
BarryK's Avatar
BarryK
Sorry I don't have an answer for you bit I'm having the identical problem in my '65 coups also so I'm waiting to hear what solutions people will come up with .
talk about an annoying rattle!
Old Jul 18, 2004 | 08:38 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
We use to use silicon spray, this acts as a lubicate.
Old Jul 18, 2004 | 10:29 PM
66BBCoupe's Avatar
66BBCoupe
2025 C3 ('68-'73) of the Year Winner - Unmodified
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
Default Coupe Halo to side rattle - Buzz
I have the same issue - engine/sidepipe vibrations transfer directly through the body and resonate easily through the thin halo panel side skirts just by occupants head - pass and driver. I ignore this as it comes and goes depending on revolutions etc. If I were to go after this issue I would losen the halo panels (the dog legs need to be losened as well) and insert very thin foam or even cloth - just to eliminate the halo panel skirts from touching the coupe side roof panels. This should solve the issue for you.
To Tricks to stop interior squeeks?
