poly bushing
Old Jul 19, 2004 | 09:44 PM
Vandoren's Avatar
Vandoren
Default poly bushing
Hi all!
I did a frame off on my 64 last winter and i went with poly bushing all around. It's been almost 3 months since i've been able to drive the car again but the bushing have started to squeek Is there a way to make it stop? I did grease them when i did the install and i didn't think they would squeek... guess i was wrong!
Old Jul 19, 2004 | 10:16 PM
Ron Miller's Avatar
Ron Miller
Originally Posted by Vandoren
Hi all!
I believe I've heard there are two types of poly bushings, those that squeek and those that are going to squeek. And the only sure way to stop it is to replace with the original rubber ones.
Maybe someone else has had other experience and will have a better suggestion!
Old Jul 20, 2004 | 07:03 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
get side exhaust & squeeeks are gone...................A little humor, anyways initially they needed to be liberally lubricated with the special grease supplied with the bushings, i went to a Marine boat supply house & bought waterproof grease & really overdid it my bishings dont sqeek , but as noted initially i have cside exhaust & I cant hear the squeeking if they do make any noise, but my 66 rides & handles great .worked for me....
Old Jul 20, 2004 | 11:51 AM
JohnZ's Avatar
JohnZ
The only way to stop the squeaks is to replace them with the OEM rubber bushings; the only people who benefit from poly bushings are guys with race cars and the poly bushing salesmen.
Old Jul 20, 2004 | 12:56 PM
65coupe's Avatar
65coupe
I couldn't disagree more.
The only caveat is make sure you get the graphite inpregnated poly bushings. They are design not to squeak. I had them installed two years ago with no sqeaks at all along with a comfortable ride and great handling. OEM rubber bushings may look ok down the road but they get compressed (squashed) and without the owner realizing it they begin to loose to loose their handing features. It's like rubber hoses, they make look OK but the die from the inside out. The "quality" life of rubber bushings is 5 to 7 years depending on use. Also make sure you have absolutely no oil leaks as that will accelerate the decline even faster. Oil eats rubber. After that its all downhill. The only negative is if you are looking to avaoid loosing NCRS points.
Old Jul 20, 2004 | 04:44 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
This may be true about what you say about rubber....But the rubber on my 65 has been there since 65..!!! It still working ok. I had a therad going in regards to poly vs rubber and have seen the Light. It's rubber for me.. Like SWC Duke Says..." If poly is that good for your suspension
System...how come new car mfg are still using rubber??
I have ordered VBP new "A" arms with good old (where ever it comes from) rubber....No Auto Crossing for me....Just a smooth " Big Butt Caddy Ride"
Old Jul 20, 2004 | 06:48 PM
65coupe's Avatar
65coupe
Why did car manufacturers use rubber?? Why else....it's cheaper. Back in the 60's & 70's the average life of a car was 7 years. the same life span of rubber bushings.
GM never built a car with old car collectors in mind. I'm a numbers matching correct car guy that likes to drive it. Visually I can't tell the difference between the two once they are installed. I put poly in my '66 when a friend told me how good they were in his 68 camaro cruiser. He said he would do mine for a little more than a six of beer. Couldn't beat the labor cost. The rubber ones looked fine until you get them out and you'll find they have no body left to them. Think about it...would you drive on '65 rubber tires or use '65 rubber hoses...NO WAY. Use [graphite] poly and the job is done forever.
I will change to poly on my '65 soon. I already bought the kit. Too bad the previous owner didn't put in poly, then I wouldn't have to replace his rubber replacements.
Good luck on whatever you use.
Old Jul 20, 2004 | 08:50 PM
Viet Nam Vett
2015 C2 of Year
Quote*
This also may be true....But are todays 50K To 100K Luxury Sedans and newer Vetts using Rubber or Poly???
Can some one address this??? If they are using rubber I doubt if it's a price concern when your building a $100,000.00 Car.
So ...who can answer this perplexing question???? Or are we just beating a dead horse? Cheeezzzz... A $5.00 dollar Bushing..
Old Jul 20, 2004 | 09:28 PM
toddalin's Avatar
toddalin
I also have these in my '64. On installation they note not to lube them. We didn't and they squeeked terribly... at first. But that was gone within a couple hundred miles and they never udder a peep since.
Old Jul 21, 2004 | 03:03 PM
w1ctc's Avatar
w1ctc
[QUOTE=Viet Nam Vett]Quote*
Good point!!
Old Jul 21, 2004 | 04:38 PM
Boogieman65's Avatar
Boogieman65
[QUOTE=w1ctc][QUOTE=Viet Nam Vett]Quote*
I had graphite/poly bushings installed , ONCE! Squeaked to beat the band. Terribly annoying. Never did stop. Worse in cold weather. I eventually sold the car, squeaking and all. It's rubber for me from now on.
Old Jul 21, 2004 | 05:14 PM
JohnZ's Avatar
JohnZ
Nope, not true. Rubber was chosen (and is still chosen 40 years later on all cars and trucks) due to the zero-maintenance characteristics and natural compliance properties of rubber, which determines both ride harshness and long-term component durability. There are thousands of different designs of rubber bushings, using differing durometers and voiding patterns to result in different compliance characteristics in different radial directions to "tune" suspension response levels under varying acceleration, braking, and lateral loadings and balance them with NVH (noise, vibration and harshness) goals.
Poly bushings sacrifice everything noted above that's important to a design engineer as the trade-off for zero compliance; that's great for racing or autocrossing, but may not be a great compromise for a street-driven car, and it beats the bejezus out of the chassis (and body). Different strokes for different folks is fine, you just have to accept the downside of the compromise.
Rubber has nothing to do with "cheap" - it has to do with achieving overall design goals; been there, done that.
Old Jul 21, 2004 | 06:22 PM
Viet Nam Vett
2015 C2 of Year
Thanks John for clarifying the above......Squeak...Squeak...Squeak.
Old Jul 21, 2004 | 08:50 PM
SWCDuke's Avatar
SWCDuke
John knows, but few realize the amount of engineering that goes into selecting bushing design and material durometer ratings to acheive a good ride/handling compromise - even back when C2s were designed.
If you understand this, you would not throw away all this good engineering by replacing the rubber bushings with something made in some out of the way industrial park.
Duke
Old Jul 21, 2004 | 09:27 PM
bondtimbond's Avatar
bondtimbond
...and the beat goes on.........and on......and on..... :-)
To poly bushing
