After some oil clean-up and some looking i noticed that the under side of my distributor was leaking oil . Being the back-yard mechanic i removed the distributor and discovered that it was coming from a vent hole from the underside . Now that the distributor is fully removed is this a parts replacement or do i need a new distributor.I dont know what would cause the oil to come from the vent hole? If i get a new distributor would this solve this oil leak problem. Thanks
Year? Distributor type? OE or aftermarket? I'm not aware of any "vent hole" on the common Delco single point distributor.
Dukr
I dont believe this is the original distributor/bought the car with a 350.
The distributor has the following information:
ACCEL-34100S
Serial No.I10323
Replacement parts
Contacts-110228
Condenser-100107
Dist.Cap-120326
Rotor-130319
Dwell Specs 14-26.5 degrees
There should be a gasket where the distributor meets the manifold.
Was it there? In good shape?
The gasket was in place when i removed the distributor and fully intact.When i seperated the distributor(two screws from underside)there was oil where the advance weights are installed and dripping out of the small vent hole and down the distributor housing.
Per Duke's inquiry, this is NOT original. Don't know exactly how its made but sounds like the upper seal and possibly bearing is worn out. It should not be getting oil inside. Put in a good GM unit.
Improper crankcase ventilation will also cause oil to be blown past the seal, make sure your pcv valve is operating properly.
Here's what I found so far. When I purchased the vehicle 1961/2 years ago the guy had a 350 in it-1969 SMALL BLOCK.Has 461 heads/duel carbs with the manifold. Dont believe it has a pvc valve. The distributor I went out to purchase for a replacement is showing it with a vacuum advance. The distributor that I removed was not set-up with a vacuum advance. What distributor would work?
From: Emporia, pay no attention to that man behind the curtain, KS
For street use the distributor with vacuum advance is better. You will get better overall performance and fuel economy. Distributors without vacuum advance are designed for racing. There has been a great deal of discussion on vacuum advance on this forum if you want to learn more.
So here goes again! This is only a street car-weekend driver. I had the distributor sent out for repair of upper bearings etc because i could not locate the same as what came out. I dont know what the guy did before me with the set-up. I do know that it was a mechanical advance that I removed. I f i were to purchase a vacuum advance where does the hose go from the the vacuum advance on the distributor-or does it have one. I noticed that aft of the carburator on the manifold there is a small 1 1/2" nipple with a hole through it.When vehicle is running I believe that there is air coming out of it.With a vacuum advance is that where a hose would attach to? Thanks for all of your guys help.
vacuum advance connection
The vacuum advance is connected from the vacuum cannister on the distributor directly to manifold vacuum. What kind of carburetor do you have? If it is a "pre-emission" type it will probably have a small nipple that provides constant vacuum. This is the connection you should use. The later carbs also have a nipple that provides "ported" vacuum. If you have a newer carb that has this feature, you don't want to use this connection. The "ported" connection only provides a vacuum source above idle; there is no vacuum from this port at idle. Connect the vacuum advance to the port that has manifold vacuum at idle. The best way to tell which port is which is to connect a vacuum gauge to each while the engine is idling.
Not so sure what you mean by this. If this is an open vacuum port, it needs to be plugged if it is not being used.
