Powerglide Kickdown Adjustment
Old Jul 29, 2004 | 01:16 PM
Paul L's Avatar
Paul L
Default Powerglide Kickdown Adjustment
I was out this morning and noted that I have lost "passing gear" since converting from Holley to Edelbrock. Does anyone have a step-by-step procedure for adjusting the carb transmission rod properly?
Old Jul 29, 2004 | 04:43 PM
JohnZ's Avatar
JohnZ
Paul, the procedure is in the M35 section of the Assembly Manual and in Section 7 of the Chassis Service Manual (assuming your Edelbrock carb has the correct linkage arm and connection like your Holley had).
Old Jul 29, 2004 | 07:59 PM
Paul L's Avatar
Paul L
John,
I have both of those reference documents. I have made some adjustments. We shall see tomorow.
To Powerglide Kickdown Adjustment
