Help needed with Distributor/Carb??
When I have the vaccum advance hooked up the car idles smooth, takes off good andruns good in traffic. But if you want to kick it in, there seems to be no power.
On the other hand, if I disconnect the vaccum advance the car kicks in great and burns rubber in 3 gears. But at idle it's rough, hard starting, wants to backfire through the carb and doesn't sound all that great.
I'm not sure if it's in the distributor (springs?) or maybe a power valve has blown in the carb. Can anyone offer any advice?
Rondog
What is the vacuum can number and specs?
Is the vacuum can signal line full manifold vacuum or "ported"?
What is the total idle timing - timing at idle speed with the vacuum can connected?
What is the idle speed and manifold vacuum?
Duke
Yes, the vaccum advance was plugged at the carb when I timed it.
WIll have to look up number or specs on vaccum can. I can tell you it is the stock one that came with the car. L-79 327/350HP with the K-66 (?) air injection system that has been removed.
It is hooked up to the ported vaccum on the carb above the base plate.
Total timing I would guess to be about 16-18 with the vaccum connected.
Idle speed is about 750-800 Rpm Do nont know what vacum manifold pull is at this time.
Rondog
As far as I know, K-66 used the same vacuum can, but a ported vacuum source, which was for CA emissions compliance. (The 300 HP engine with K-66 had a very different advance map.) If you have the AMA specs that are part of the complimentary GM restoration package, I would like you to post the ignition map specs for K-66 if they are different than 49-state models. If you don't have the AMA specs call GM Customer Service and request the restoration package.
You want a FULL TIME manifold vacuum source for the vacuum can, NOT PORTED!!!
At idle, your TOTAL timing should be the sum of initial, plus full vacuum, plus probably a few degrees of centrifugal since you have a quick curve. Connect the vacuum can to a FULL manifold vacuum source, and verify that the total idle timing is at least the sum of initial plus full vacuum advance. I would also suggest that you check the vacuum can with a Mighty Vac and dial back timing light to verify that it performs to spec. Those internal rubber diaphragms don't last forever.
Once you have completed the reconfiguration, go through the idle speed/mixture adjustment procedure.
Your centrifugal curve may be a bit too fast. If the problem persists with full time vacuum advance slow it down a little so it's all in by about 2500.
If you or anyone else has the AMA specs for your model year, perhaps they could research them and tell us any difference in the timing map for L-79 and without K-66, but you need to state your model year.
When posting a question please state the model year and engine option and whether it is OE or modified, and any other information that may be relevent, such as it was originally built with K-66. Saying "stock 327" covers a lot of model years and engine configurations.
Duke
I happen to have the AMA restoration package and the specs. The Air Injection Emission control has the same specs for the distributor as the one without. They are as follows:
Centrifical Advance begins at 900 RPM
Max Degree is 30 @ 5100 RPM
Vaccum Advance Begins @ 4 In Hg
Max Degree is 16 @ 7 In Hg
Initial Timing is 10 BTC with vaccum line disconnected @ 700 RPM
I initially thought about purchasing an Accel Advance can that has the adjustable screw setting inside to see if this would help.
I will have to get all my other vaccum and mighty vac out this weekend to get the other specs you discussed earlier.
Appreciate your help with this matter.
Rondog
One other question. Do the AMA specs or CSM show a different carb number for K-66 versus non-K-66. I'm pretty sure K-66 would have included ported vacuum advance, which would be evidenced by a different carb number.
I think all you need to do is verify that your vacuum can is reasonably within spec, be sure it's connected to a full manifold vacuum source, and maybe slow down the centrifugal a hair.
Duke
The different carb for K-19 was probably due to a provision for ported vacuum advance rather than full time vacuum advance w/o K-19.
Duke
Duke
GM also addressed the issue by setting curb idle speeds high, which could cause the engine to "run-on (or "diesel") when the ignition was shut off. To solve, this a solenoid throttle stop was sometimes installed that was energized whenever the ignition was on. When the ignition was shut off, the solenoid de-energized and allowed the throttle to close to the low idle stop, which starved the engine for air so it would not run-on.
The throttle dampers are a real nuissance because they cause the revs to hang on upshifts (like a very heavy flywheel) making it very difficult to execute a normal speed upshift, smoothly. The high curb idle speeds also contribute to rev hanging, but not as bad as the dampers.
Modern digital control EFI systems shut off fuel flow at closed throttle overun or when a rapid throttle closure is detected, which usually means that revs drop off quickly for quick, smooth upshifts.
Duke
