Question for C1 Guys
Old Aug 15, 2004 | 10:02 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Default Question for C1 Guys
I am looking for a plain white, no shift pattern, shift ****.I want to put it on the Hurst shifter on the 65. In pictures I have seen of many C1s, the **** look plain white. Do they have the shifty pattern embossed on them? What is the **** diameter? What is thread is used? Is the thead a metal insert or just tapped into the plastic ball?
Tom
Old Aug 15, 2004 | 10:05 PM
John McGraw's Avatar
John McGraw
The original **** for most C1 cars is just a plain white plastic **** with no shift pattern. The pattern is always screwed to the shifter boot bezel. The original **** was threaded directly into the ****, but most replacements for the last 20 years had the brass insert in them.
Regards, John McGraw
Old Aug 15, 2004 | 10:41 PM
62fuelie's Avatar
62fuelie
One of these ***** might work on the Hurst, but they are a lot smaller than the Hurst ****. Not sure if the threads are the same, but if memory serves, the Hurst is going to have larger threads.
Old Aug 15, 2004 | 11:02 PM
Ironcross's Avatar
Ironcross
I have been using a cue ball. I just drilled and tapped the hole then screwed it on the shifter.
Old Aug 15, 2004 | 11:31 PM
Cruzmeisters's Avatar
Cruzmeisters
Cruz
Old Aug 16, 2004 | 09:25 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
[QUOTE=Sky65]What is the **** diameter? What is thread is used?/QUOTE]
**** diameter=1.5"
Thread= 5/16" x 18
Old Aug 16, 2004 | 02:27 PM
Sky65's Avatar
Sky65
Thanks all for the replies.
I will do some measuring now to come up with my final solution.
Tom
To Question for C1 Guys
