suspension upgrades
thanks
greg
The OE base suspension is very good. If the springs are free of major corrosion, they should continue to be used. You should consider removing the rear spring and rebuilding it - disassemble, check for corrosion, clean and apply a corrosion resistant coating, and reassembly with new liners.
Install the spring with new link cushions.
For best performance (assuming you have decent tires) set camber at
-1 front and rear and install hard urethane bushings on the front anti-roll bar links. Set front caster at 1.5-2.0 degrees with manual steering and 2.5 with P/S. Greater camber improves straight line tracking and steering feel, but yields higher effort, especially at low speed. Establish front toe-in at 1/16" and rear toe in at 1/32" per wheel with radial tires
Top it off with a set of adjustable shocks like Spax.
http://www.spax.co.uk/
Spend your money on tires, shocks, rebuilding the OE suspension components as necessary and alignment tuning. The ride rates, roll stiffness and roll stiffness distribution is excellent as is.
Duke
Available tire grip is 90 percent of the handling equation. Everything else in the suspension is just a matter of tuning to get the most out of the tires.
Bob Riley, one of North America's premier race car designers, says that 90 percent of setting a car up is tuning shocks, which is why I recommend adjustables.
Duke
The C3 FE7 package effects a dramatic increase in roll stiffness with both stiffer springs and much larger anti-roll bars. Recall that the anti-roll bars' contribution to roll stiffness is a function of diameter to the FOURTH power, so even a 1/16" change has a dramatic affect on the numbers and is definitely noticeable SOTP.
Note that the small FE7 rear bar is accompanied by a HUGE 1 1/8" front bar. (base supension C2 front bar is 3/4", 15/16" w/F40) If you install this setup on a C2 it will have higher rear roll stiffness distribution because of the higher C2 rear roll center. Installing the small rear bar (7/16") without at least a 1 1/8" front bar on a C2 will probably result in excess oversteer. The base SB suspension on C2s is quite neutral. In fact, if anything they are a little to tail happy at the limit. Installing urethane bushings on the front anti-roll bar links will mitigate this situation. Eliminating compression of the rubber bushings increases front bar effectiveness at high deflection, which will effect a bit more understeer at the limit and help keep the tail in line.
The one "upgrade" I would consider on the base C2 SB suspension is installation of the 13/16" front bar that was part of the later C3 base suspension package. This bar in combination with negative 1 degree front camber and hard link bushings will improve steering response with a little less roll and a little more understeer at the limit to keep the car stable.
Body roll is not all bad. It gives the driver feedback as to where the car is in the dynamic envelope. As you increase roll stiffness the car will become "edgier" and more difficult to recover if you step beyond the limit of its dynamic performance envelope.
An illustrative example is the relative setup of a formula car for wet road conditions. If a dry setup is used the cars are virtually undriveable in the rain. A wet setup is considerably softer - both springs and bars, which dramatically reduces roll stiffness.
Duke
