C2 (64) Shock Question
Old Sep 6, 2004 | 07:51 PM
Snoozer's Avatar
Snoozer
Default C2 (64) Shock Question
I am changing the rear shocks on my 64. I have the bottom nuts off and the top bolt loose and the nut off the back. How do you get the top bolt out? Thanks for any help, Snoozer
Old Sep 6, 2004 | 11:32 PM
jimdvan
It should just pull out. If the head is on the outboard side, which it should be, pull it outward or use a wrench to turn it out in case its a little tight.
