Steering Column Problem
Old Sep 12, 2004 | 07:00 PM
ajtorsiello's Avatar
ajtorsiello
Default Steering Column Problem
Been busy building a neew house so I haven't had much time for the '66. But this weekend I went to the garage and when I went to drive it it seems that the steering column bearings are binding. I don't want to rebuild my column because my shaft is no good. Someone in the past buggered up the teeth on the end and then drilled a hole thru the rag joint and the shaft and put a bolt thru the whole mess. Anyone know where I can get parts to repair this mess or a company that reproduces a column? Any help will be appreciated.
Old Sep 12, 2004 | 07:06 PM
MOTORCITY's Avatar
MOTORCITY
All the parts are available, including the shaft. Paragon or Long Island Corvette, have the parts.
Old Sep 12, 2004 | 07:19 PM
ajtorsiello
Thanks for the lead, I'll check it out tomorrow.
Old Sep 13, 2004 | 11:24 AM
JohnZ's Avatar
JohnZ
You can also try Corvette Steering Service (www.corvettesteering.com); they have everything you need.
To Steering Column Problem
