correct spark plug
Old Oct 7, 2004 | 07:24 PM
wib1961's Avatar
wib1961
Default correct spark plug
I'm sorry to beat a dead horse but I went to Advance Auto to get plugs for my '61. Their computer said R43S for my base 283ci/ 230hp. I believe this has been talked about before with similar plugs but I wanted to be sure. Is there an issue I need to address with these plugs?Thanks Wib
Old Oct 7, 2004 | 10:19 PM
SWCDuke's Avatar
SWCDuke
R45
Duke
Old Oct 7, 2004 | 10:29 PM
magicv8's Avatar
magicv8
I believe your owners manual will say you need nonresistor plugs. If you still have an original coil, resistor plugs and resistor wires will overload it.
I still have a box or two of ac 43s or 44s (s means extended tip) plugs around the garage. They are also for sale in the NCRS Driveline. If you have a replacement coil or metal core wires, use whatever works - and don't worry.
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Originally Posted by SWCDuke
R45
Duke
I think the saying goes something like "garbage in, garbage out". They may have a great computer but whoever put that information in it has no business in that business. 43's have a place in race engines or as a bandaid in a terminally lean engine.
Old Oct 7, 2004 | 11:40 PM
SWCDuke's Avatar
SWCDuke
Since AC no longer makes non-resistor plugs, many use resistor plugs with no apparent problems. AC heat range "5" works best on all street driven SBs.
If you want a true non-resistor plug equivlent to the AC 45, the NGK B4 or Denso W14-U fill the bill.
Duke
Old Oct 8, 2004 | 07:16 PM
wib1961's Avatar
wib1961
Guys thanks again for the greatly appreciated info. I believe I will return the R43s and look into other options.
Old Oct 9, 2004 | 12:16 AM
Ironcross's Avatar
Ironcross
R 43`s will be too cold.
Old Oct 10, 2004 | 10:46 PM
magicv8's Avatar
magicv8
To correct spark plug
