odometer question
Old Oct 8, 2004 | 03:21 PM
bovette's Avatar
bovette
Default odometer question
On my 64 roadster, all my gauges are perfect execpt my odometer doesn't work. Does anyone have any suggestions how or where to get this fixed? Also, how difficult is it to remove the odometer from the cluster? Thank you in advance.
Old Oct 8, 2004 | 04:36 PM
Allcoupedup's Avatar
Allcoupedup
Odometer is connected to the speedo and once the cluster is removed there are 5 or 6 screws. Removal of the cluster is the hard part!
brian
Old Oct 8, 2004 | 11:02 PM
65RDSTR's Avatar
65RDSTR
http://www.corvetteinstruments.com/catalogindex.htm
This guy could fix it or you might be able to get the parts you need from him. I havent fixed mine yet but I tore it open and found two brass worm gears in the spedo that were worn out. I will probably have to replace the whole spedo mechanism because it doesnt look like it comes apart that far. I will probably get mine done this winter. Id like to here what you come up with.
Old Oct 9, 2004 | 07:18 PM
JOliver's Avatar
JOliver
Speedo working correctly and the odometer not working is common in MidYears(53-82 Vettes for that matter).
The speedo works off of magnatism and has less wear than the gear driven system that works the odometer.The odometer wheels themselves get hard to work and will lock up.
I can help you get it working again.
VetteInstruments@aol.com
Jason
Old Oct 11, 2004 | 04:09 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Speedometer repair service, Roswell georgia, they rebuilt my odometer for 90 bucks & calibrated speedo >>>>>>>turnaround time was 8 days............worked for me the Dog.
Old Oct 12, 2004 | 09:46 AM
StrayDog's Avatar
StrayDog
Speedometer repair servce 1-800 241-2385 ssc@speedometerservice.com....Worked for me the Dog
Old Oct 13, 2004 | 01:23 AM
Cmacsvette's Avatar
Cmacsvette
bovette & 65RDSTR,
Just my 2 cents here. JOliver who responed to your post, is who did all my instruments. He has done instruments for other forum guys too. I had another company do them and they screwed them up bad. I feel that Jason is one of the VERY BEST out there! These words are coming from an **** guy too, "me". His turn around is good and the price is right. With all the hackers out there that stick it to us in this hobby, I gotta tell ya,..................it's a real pleasure to find someone honest or should I say, who has INTEGRITY and takes a lot of PRIDE in his work. Two up.
Craig
To odometer question
