Bilstein shocks
Old Oct 17, 2004 | 07:36 PM
00fxd's Avatar
00fxd
Default Bilstein shocks
I had a ride in a mid year once that had the whole full meal deal "VetteBrake" Fibre Glass Leaf spring system front and rear, with Bilstein shocks. I found the rear spring bouncy and I did not like it. I'm told that if you have the right shocks that should not be a problem. I feel that there is a possibility that I may install the Fibreglass leaf spring in my car in the future for weight savings so I would like to install the correct Bilstein shocks now. Does anyone know if I should use the Bilstien "H.D's" or the Bilstein "Sports"?
Old Oct 18, 2004 | 03:09 AM
Aussi-66's Avatar
Aussi-66
I have a full vettebrakes front and rear and on my 66 roadster. I had a set of top end shocks on the car so used them with the new glass springs, it rode like a kangaroo. I called up the guys at vettebrakes and told them my problem, the first thing they asked me was what shocks are you running. I told them and they said great shocks for steel springs but not for glass. I purchased a set of bilstiens that VB has bilstien make to match their springs. The result was a complete transformation the car handles well and is a nice touring car even on the less than great roads we have out here.
Old Oct 18, 2004 | 07:45 AM
STING67RAY's Avatar
STING67RAY
ditto on above post.
had exactly same situation. vbandp sold me the correct bilsteins,
what a dramatic improvement over the steel and old style shocks.
Old Oct 18, 2004 | 11:04 AM
sting66cp's Avatar
sting66cp
I am wanting to upgrade my rear spring to fiberglass as well. I am currently using KYB shocks from Corvette Central, will I have to replace these shocks to use the new monospring?
Old Oct 18, 2004 | 11:19 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If you have the Gas-A-Just than you will need to replace your shocks and go with the KYB GR 2's or the Bilsteins. If you stick with the KYB's you have to get the GR 2's that are for the glass spring. They make 2 types of GR 2 shocks.
The bouncey spring could also have to do with the weight ratio of the spring. To soft of a spring will have you bouncing all over the place.
Old Oct 18, 2004 | 03:43 PM
00fxd's Avatar
00fxd
Originally Posted by Van Steel
If you have the Gas-A-Just than you will need to replace your shocks and go with the KYB GR 2's or the Bilsteins. >>> O.K. Bisltien what? Special construction for glass spring?
The bouncey spring could also have to do with the weight ratio of the spring. To soft of a spring will have you bouncing all over the place. >>> I don't agree with that. The soft spring will give soft ride, a strong spring will give stiffer ride. A shock will contain the bouncing. That is the purpose of a shock absorber.
Question: Would I be able to use the special glass spring shocks with my steel spring untill I jump to the glass spring?
If the fibreglass spring uses a special shock, why then does GM show the same rear shocks from '66 [steel spring] till '81 [glass spring] and the 81 is not bouncy.
To Bilstein shocks
