67 clock
Old Oct 23, 2004 | 02:21 PM
ESR's Avatar
ESR
Default 67 clock
Just removed the clock, and noticed that the back of the clock has three prong. Two of the prongs take the clip to hold the clock to the dash. But the third prong (in the middle) was not attached to anything when I removed it.
What is this middle prong for? Is it supposed to be attached to something? Is it a ground?
ER
Old Oct 23, 2004 | 02:46 PM
wilbur's Avatar
wilbur
Hello esr,
At the back of your clock there should be 2 wires + - and 3 prongs. The prongs are there for aligment and support.
Kevin
Old Oct 23, 2004 | 06:45 PM
NVaVettes's Avatar
NVaVettes
There should be two electrical "prongs", one positive, one negative.
Make sure you figure out which is which, as the clock will work if
connected either way. However, hooking it up "backwards" will cause
current to get into the clock body, the console, and other unwanted
places causing strange problems. You might want to do a search on
this issue to get more details.
Good luck!
To 67 clock
