Engine running hot
Old Oct 28, 2004 | 03:53 PM
karista's Avatar
karista
Default Engine running hot
Just finished a major restoration on my 63 Convertible. The engine received new radiator (aftermarket direct fit copper/brass), new waterpump and fan clutch (both aftermarket), the only thing added to the engine was power steering. Its a sb base 327 engine and I installed a 160 thermostat to lower the temperature, however she is still running about 220 and after I turn the engine off the thermostat reading rises to 240. This situation is new and was not a problem prior to this restoration effort. Anyone experienced a similar situation? Any ideas?
Old Oct 28, 2004 | 04:08 PM
Ryanc65's Avatar
Ryanc65
One possible problem is the replacement radiator you used. The copper/brass do not cool as well as the aluminum. Other possible problems are related to engine tuning and vacuum advance.
Check the archives for many discussions on the topic. Others may chime in with more first hand information.
Ryan
Old Oct 28, 2004 | 05:26 PM
bk2w's Avatar
bk2w
Far and away the most common cause of overheating is the engine timing. I can't speak to the settings you'll need, but a properly working vacuum-advance distributor is critical. Getting it set correctly, with the proper amount of initial advance (again, I don't know what the right settings are for your engine, I'm sure others will chime in) is the key.
Basically, without the proper amount of advance, the combustion flames run too hot, and dump a ton of heat into the engine.
Good luck,
-Brian
Old Oct 28, 2004 | 07:08 PM
Hitch's Avatar
Hitch
Lots will tell you replace the radiator but I had a brand new copper brass in mine from when I rebuilt the front end this winter. In less than 100 degree weather in traffic I never got above 220. I was using a Car Quest water pump and a 50/50 coolant mix. So it may not be your radiator but an aluminium one would help. I switched to a DeWitts stock replacement and Stewarts Stage II aluminium water, 160 Robert Shaw thermostat and now adays I never get above 190-200 regardless of how long I sit in traffic. With it being cool out now I may have to switch to a 180 thermostat just she will warm up a little quicker.
As stated above it could be your timing. However could you tell us whether the temp jumps when going down the road or when sitting? ... Dave..
Old Oct 28, 2004 | 08:15 PM
sjaroslo's Avatar
sjaroslo
From: And make no mistake, there's women who just wait for the man and machine with the best time
St. Jude Donor '08
Are you sure that you don't have a big ol' air pocket in there somewhere?
Old Oct 28, 2004 | 10:06 PM
SWCDuke's Avatar
SWCDuke
First, a lower temperature themostat WILL NOT cure or preclude overheating. The thermostat establishes the LOWEST operating temperature. The highest is established by radiator heat transfer capacity and air flow, and Corvettes received premium cooling system components such as the aluminum radiator and themomodulated fan clutch to ensure proper cooling of what is a big engine in a small car.
The first advice to all is to always used OE or OE equivalent cooling system components. Many have found that "replacement" copper brass radiators DO NOT provide sufficient cooling and results in hot running.
What kind of "aftermarket" fan clutch? Make? Part number? Is is supposed to be a direct replacemnet for the original?
Also check for proper function of the vacuum advance against specs in the shop manual, and ensure that the manifold vacuum signal line shows full manifold vacuum at all times including idle.
If would also help diagnosis if you would be more specific on when the car overheats: Idle and low speed driving? Cruising at highway speed? All of the above?
Duke
Old Oct 29, 2004 | 12:04 AM
Denney's Avatar
Denney
Duke
with Duke. Also, have you verified the actual operating temperature with an IR gun? If not you may also want to verify that the sending unit is giving you the correct reading...
Old Oct 29, 2004 | 08:53 AM
karista's Avatar
karista
Thanks for all the advice, to answer a few questions;
The engine runs hot at highway speed only, not at idle.
The fan clutch was bought at NAPA and was listed as a replacement for 63 Corvette 327 sb engine, its diamater is much bigger than the original one which was faulty.
What I also don't understand that the temparature heating goes up to 240 after the engine has been turned off, then its extremely hard to start at that temparature. Need to wait until it cools down to restart.
Has anyone installed a electric fan in place of the fan clutch? Results?
Old Oct 29, 2004 | 10:12 AM
Coves4me's Avatar
Coves4me
Along with everything Duke suggested, your highway hot-running temp suggests three things to consider:
1. collapsed lower radiator hose; is there a coiled wire in it?
2. improper vacuum advance and timing;
3. inadequate air flow through the radiator; gaps around the radiator?
Try looking at these first. Good luck.
Old Oct 29, 2004 | 10:30 AM
JohnZ's Avatar
JohnZ
First, verify the accuracy of your temp gauge by comparing the gauge reading vs. an I.R. gun "shot" of the radiator hose just above the thermostat housing so you know what the gauge is really telling you.
Heating at highway speeds but not in town generally says the radiator is inadequate, assuming the rest of the cooling system is operating properly and your advance system (vacuum and centrifugal) is set up correctly. Copper/brass replacement radiators have about 30%-40% less heat rejection capability than the original Harrison stacked-plate aluminum radiator, and are a poor place to save money.
It's perfectly normal for engine temperature to go up after shutdown - that's "heat-soak". When you say it's difficult to re-start when hot, what is the symptom? Won't crank? Cranks slowly? Cranks but won't fire? Flooded?
Electric fans are unnecessary - just a band-aid for a basic cooling system problem, and they won't help at all on the highway; airflow isn't an issue at highway speed - only radiator efficiency.
Old Oct 30, 2004 | 02:56 AM
vref's Avatar
vref
http://www.asashop.org/autoinc/june97/cooling.htm
Old Oct 30, 2004 | 03:38 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Nobody's actually said it, but IF it's your timing, it's because it's too retarded. Cars with the timing too retarded will run hot. This could be related to initial timing or to centrifugal/vacuum advance.
You state you did a major restoration to your 63 convertible. What if anything did you do to the engine? Rebuilt? Bored? Heads? etc. Chuck
Old Oct 30, 2004 | 10:12 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
If you're looking for good advice, re-read SWCDuke and John Z comments. This is where to start!
You could also look at hundreds of archive posts where people have downgraded with a c/b radiator, only to find out they run hot. You're not the first and not the last to do this, we see it all the time. Real test data shows that the c/b rads are 30% below the GM aluminum specs, so if you cut 1/3 of your radiator off and it ran hotter would you wonder why?
You might have some other issues too, maybe the temp sending unit is off, and maybe the timing is off, but in the end the c/b radiator has to go.
To Engine running hot
