FI spacer
Old Oct 31, 2004 | 08:01 AM
Hitch's Avatar
Hitch
Default FI spacer
Hey guys, the 2" side pipes that I had on the car did not need the spacer. However now with the Allen's 2 1/2" I was told I would need it. Okay I picked one up but I don't know if there should be a flat gasket between the spacer and the exhaust manifold. Need to get out there and put these on so I can enjoy this nice weather we're having.. Thanks guys.. Dave..
Old Oct 31, 2004 | 08:28 AM
Viking427's Avatar
Viking427
Probably won't matter either way but GM never used FI spacer gaskets, nor manifold-to-head gaskets.
Old Oct 31, 2004 | 09:20 AM
qwik-tripp's Avatar
qwik-tripp
my local parts store had them in stock both the flat gasket and the tapered ring. let me know about the sound difference with the new pipes.
Old Oct 31, 2004 | 10:02 AM
Hitch's Avatar
Hitch
tripp, mine were louder than stock before but that has a lot to due with my set up. I actually want them to be louder... I will report when I start her up. Another question for those running Ram horns on a 66 or 67 where did you get a bracket at to mount the alternator. I guess I can go to ACKK.. Auto Zone and pick up a chrome one and paint it black... Dave..
Old Oct 31, 2004 | 10:09 AM
JohnZ's Avatar
JohnZ
Assuming you have the correct ram's-horn manifold with the boss and hole in the front, Paragon and LICS have the lower mounting bracket and the upper adjusting brace.
Old Oct 31, 2004 | 10:20 AM
Hitch's Avatar
Hitch
John these are the ones with the mounting bracket that protrude forward and has the holes perpindicular to the manifold. So I've got to fab up something any suggestions are welcomed.. Dave...
Old Oct 31, 2004 | 10:24 AM
Hitch's Avatar
Hitch
Here is a pick of the manifolds for reference guys...
To FI spacer
