Testing Ph level in radiator
These strips are not valid for OAT antifreezes (like Dexcool), and I don't think they are valid for HOAT blends like Zerex G-05.
Off hand I don't know where you can buy these test strips, but I know they are out there. You might try your local auto parts stores for starters.
Duke
its from the tech tips section on this forum
https://www.corvetteforum.com/techti...=170&TopicID=5
Duke
Heh John,
This was passed onto me by Bill,
Quote'
GM no longer recommends shops check antifreeze with a hydrometer type anti freeze tester. Instead they provide the dealerships with a refractometer type tester which they say is more accurate than hydrometer types.
The definition for pH given in one post is almost right.
pH is the negative log of the hydrogen ion concentration in moles per liter.
A mole is the weight of an atom or molecule expressed in grams. For example, an molecule of water has one oxygen and two hydrogen atoms in the molecule. The atomic weight of oxygen is 16 and that of Hydrogen is 1, thus for water the mole weight is 18 grams.
A mole of any substance always contains exactly the same number of atoms or molecules. That number is Avagadro's number which is 6.02 x 10 to the 23rd power. Big number.
pH test strips (Litmus strips) can be used to test coolant pH but some color shift will occur as a result of the coloring of the antifreeze. It is a gross test at best to use swimming pool strips.
Un-Quote.
Check Out This...More on Ph... Word Document.
http://www.geocities.com/daulquad/ph.doc
Man.....glad I do electronics and not the above gack...
