C2 keys
Old Nov 5, 2004 | 08:35 PM
65RDSTR's Avatar
65RDSTR
Default C2 keys
What keys are supposed to match each other. I know the doors and ignition use the same key. Are the glove box and spare tire lock a different key?
Old Nov 5, 2004 | 09:10 PM
vark_wso's Avatar
vark_wso
On all midyears, both doors & the ignition use the same octagon key (Briggs & Stratton) with the teeth down. In '63 & 64, this same hex key also opens the glove box. In '63 & '64, a separate oval key (Briggs & Statton) operates the spare tire lock only. For '65-67, the spare tire lock & the glove box use the same (oval) key. '67s also have a different keyway in all lock cylinders. There is an 'A' stamped on the ignition/door key, and a 'B' stamped on the glove box/spare tire lock. Thus, a '67 uses different (& difficult to find) key blanks unless you are satified with the goofy hardware store look.
Old Nov 5, 2004 | 09:39 PM
magicv8's Avatar
magicv8
I had a locksmith (Jesser?) at a Bloomington show key all my locks the same on my 66. Sure is handy.
Old Nov 5, 2004 | 11:03 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
ALL 1963-64 models have a SINGLE Briggs & Stratton OCTAGON key to operate the ignition, the doors, the glove box and the spare tire lock - not two keys
Old Nov 6, 2004 | 11:29 AM
JohnZ's Avatar
JohnZ
Joey Jesser has done all my key work for years - not cheap, but top-notch work, and one of the few sources for REAL original blanks with the correct keyway codes.
Old Nov 6, 2004 | 09:01 PM
mdz06vetter
Pat Kraus - Pat's Lock and Keys - Fallston, MD also NOS Briggs & Stratton originals
To C2 keys
