Engine compartment wire routing
I've got the assembly manual but it's not that clear in the case of the 65 with A/C. I'm especially interested in the harness that goes across the firewall from the back of the fuse panel that connects to the starter & compressor, etc. That along with the other wires that come through the firewall from the recess around the wiper motor. Plus I have 2 clips that are/were mounted with screws and I'm fairly certain one goes on the lower bolt for the heater connection panel and holds the starter wires but the other is a mystery right now along with which riveted clips hold which wires.
thanks guys,
Ken
PS One more thing - the assembly manual indicated the positive cable from the battery is to be routed 'under' the parking brake cable. The negative cable obviously goes that way but the riveted clips that held the positive cable previously appear to route it over the PB cable. Again, this is an A/C car with the battery on the driver side.
I've done some searching on the forum but haven't found anything yet. I'll give it this evening for more responses and then may introduce myself to Gary tomorrow.
Thanks Dave,
Ken
Take a road trip and head North and check it out Gary's engine compartment for yourself. It is all original under the the hood so you might get some valuable info. Gary's retired and he would be glad to help out a fellow enthusiast.
The A-C harness is an add on. It does not come though the fuse box connectors, and it requires heater blower wire be disconnected in the engine bay and cut and taped under the dash. It is in the AIM.
Ask more questions if you need help with anything to do with wiring except "correct" placement. I route the wires where it keeps them safe, and I protect the harness in loom casings.
