Cam for BB
Old Nov 20, 2004 | 10:16 PM
tdelph's Avatar
tdelph
Default Cam for BB
I am having my BB finished and I decided I wanted a cam that sounded very strong and throaty. My engine guy recommended that we step up to the CompCam XE284H, is anyone familiar with this cam? My car is a good candidate for the more radical cam, because I dont have any thing that requires the vacuum. Such as, PS, PB, AC etc.. But until recently I thought that this was a good move. A few of you have said recently that its easy to go through cams in the BB's if your not careful. Any advice on how to be careful? I had the Roller rockers, lifters, push rods etc...stepped up, per the compcams tech support to make sure that we put the recommended support in the heads.
Old Nov 20, 2004 | 11:06 PM
Birdball's Avatar
Birdball
what compression are you running? The XE line from Comp cams are good for building cyl. pressure in lower C.R. motors which means if you put one in a high compression engine, you could be in ping city....
Also what gears and trans?
Old Nov 20, 2004 | 11:23 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The cam affects a lot more than just how the engine sounds so you need to consider everything else that it does affect and how it works with the rest of your engine and car. Ideally, the cam you select will provide the power you want and where you want it. More information about your car (gearing, etc,) and how you use it would be helpful.
Old Nov 20, 2004 | 11:34 PM
tdelph's Avatar
tdelph
I believe that it has 9.5.1 compression and I am running 3:73 gear. I feel confident that the engine builder and Compcams went over the basics. I was just concerned with the threads that described the BB's eating cams and didnt know if there was any particular reason for this...something that I should look for...other than the obvious.
Old Nov 20, 2004 | 11:35 PM
tdelph's Avatar
tdelph
muncie 4 speed...forgot to mention that
Old Nov 21, 2004 | 02:41 AM
NINETNINEVETT's Avatar
NINETNINEVETT
I have a 454 with a 268 comp cam 342s runs great and fast. How much do you need??? You take more chances of breaking thing when you go to big of cam and not do everything right to go with it. Be carefull or your engine builder will be doing it a second time and you will PAY
Old Nov 21, 2004 | 11:10 AM
JohnZ's Avatar
JohnZ
Stay away from the "hot-rod" ultra-high valve spring pressures - that's what kills valvetrains, especially in big-blocks. You have to decide whether you want a reliable street engine with good torque or high-rpm power with less reliability; there's no "free lunch".
Old Nov 21, 2004 | 08:45 PM
tdelph's Avatar
tdelph
good advice all. I think that maybe a notch down in the aggressiveness in the cam should be a consideration. I do want a nice strong loppy sound, but more important, I need the reliability of the stock 427's.
Old Nov 21, 2004 | 10:56 PM
SWCDuke's Avatar
SWCDuke
Why not use the L-72 cam?
Duke
Old Nov 22, 2004 | 09:04 AM
tdelph's Avatar
tdelph
SWCDUKE,
which cam is this? Is it a Compcam? I didnt see it in the XE line of cams when I looked.
Old Nov 22, 2004 | 10:51 AM
SWCDuke's Avatar
SWCDuke
No, it's the OE 427/425 HP mechanical lifter cam and is available from Federal Mogul Speed Pro.
Most aftermarket cams have too much overlap. The OE cams are a better way to go. They use OE valve springs and you likey won't have valvetrain problems if you have the lash set properly and you don't overrev.
Duke
Old Nov 22, 2004 | 11:09 AM
tdelph's Avatar
tdelph
gotcha...thanks for the info.
To Cam for BB
