ECL codes...????
How is this possible? Can anyone shed light on this?
Below copied form NCRS website --
This book provides the means by which original GM issued Corvette trim tag examples can be both INTERPRETED and IDENTIFIED with objectivity by any motivated person with the knowledge contained within and a few simple tools. The bottom line is that all Midyear tags came from a like master and demonstrate identically repeated aberrations. As a practical aid for enthusiasts, a huge number of these aberrations have been photographed, catalogued, and documented. This research allows for an extremely reliable system for identification of original trim tags. ((((((((The “translated” ECL code schedules mean that you can also identify appropriate options originally on the car with absolute certainty- not just exterior and interior colors! ))))) While this book contains extreme close-up photos of the various embossed characters to demonstrate the repeated aberrations, nothing more than a small flashlight and inexpensive 10-15x magnification loupe is necessary to benefit from the knowledge in this book. The book is coil bound, 8 1/2 x 11 inch format with 124 pages of text, tables, and extremely detailed photos
An ecl cannot tell you if it was a 250 hp car or a fuel injected car, however . . . just things that IMPACT on interior panels, like A/C, P/W, etc.
ALL options, not just trim colors, had ECL codes (you'll see them as 2-character suffixes on each option listed on the tank and window stickers) - the production scheduling computer used them to generate the Body and Chassis Broadcast sheets for each car that identified each part for the guys on the line to put on that particular car, so they didn't have to decode an ECL chart of part numbers for each car to get the right part number for that car.
