Restoring script valve covers?
Old Dec 21, 2004 | 11:02 PM
Marks69BB's Avatar
Marks69BB
Default Restoring script valve covers?
I have original corvette script aluminum valve covers on my 65 coupe. They look dirty and dull. What do you do to restore them? I like bright work so the shinier the better!
Old Dec 21, 2004 | 11:27 PM
78Vette-SA's Avatar
78Vette-SA
If you want "correct" there are several places to send them to be reskinned so they will look like factory. Other options include a good cleaning or sandblasting and a spray like Alumi-Blast. I've also taking High Heat VHT Aluminum paint and sprayed them and then wiped them down with a clean rag while still wet. Gives them a smoother, less metallic look.
My .o2
Old Dec 21, 2004 | 11:29 PM
Hitch's Avatar
Hitch
Mark, I just polished mine up with a buffing wheel, Incorrect yep, looking good, yep... Dave.
Old Dec 21, 2004 | 11:50 PM
LouieM's Avatar
LouieM
I thought there was just one place that "reskinned" aluminum parts, at:
http://www.z28camaro.com/restosvcs.html#AIM
Are there other places? I'll be getting this done to my 67's intake and valve covers this winter, and knowing an alternate place to send them might be useful.
Old Dec 22, 2004 | 12:00 AM
62fuelie's Avatar
62fuelie
John DeGregory also does aluminum refinishing. JohnDeGreg@aol.com
Old Dec 22, 2004 | 09:06 PM
project63's Avatar
project63
The covers on your 65 should look like this. Note the absence of the casting flaw across the "o". These covers are getting rather hard to find in good shape. If you want a "shiny" set, please get a set of the common ones WITH the casting flaw and buff them. You can remove the flaw during this process and nobody will know the difference anyway. I hate to see anyone ruin a good set without the flaw by buffing the natural finish away. If you like the finish in the picture, I can help you. Price will depend on the existing finish condition, but it's usually around $75 a pair.
Old Dec 22, 2004 | 09:38 PM
vref's Avatar
vref
I would send them to Fred Hudson in Oklahoma City. He has a huge vibratory tank for refinishing aluminum parts. His number is (405) 942-2729
Old Dec 23, 2004 | 01:30 AM
Marks69BB's Avatar
Marks69BB
Thanks for the replies. I was worried about messing up what I thought were GM NOS originals. Since mine have the casting flaw, I'll hit em with a buffing wheel.
Old Dec 23, 2004 | 06:50 PM
project63's Avatar
project63
Yours could still be NOS but all "493" script valve covers from GM after March 66 (around Vin 17000) have the flaw across the "o".
That's what makes the "no flaw" versions so valuable.
To make the buffing job go faster, wet sand first with progressively finer grades of wet or dry paper to even the surface and remove minor surface imperfections. Start with 120 and finish with 600 grit and then buff away. They will look pretty dang spiffy, but unless you clear powder coat or otherwise clear coat them, the shine will oxidize and dull in 10 or 12 months.
Go to Caswells and get some good compound and specialized buffing bobs for the tight spots around the script.
good luck,
tc
To Restoring script valve covers?
