'67 Steering Column........
Old Jan 14, 2005 | 09:02 AM
Bowtie67's Avatar
Bowtie67
Default '67 Steering Column........
I am working on a '67 steering column(Non Tele). Both bearings needed replaced so I have it totally apart. The collapsible shaft telescopes in and out. Can anyone tell me what the exact overall length of the shaft from end to end should be? I know that it originally was fixed in place by hot glue or nylon. I want to get it positioned correctly for bearing spacing and preload.
Old Jan 14, 2005 | 10:45 AM
JohnZ's Avatar
JohnZ
The plastic pins through the two shafts were originally "injected" into the holes; if you move the inner shaft in the outer, at one point the holes in each will align - that's the correct position for both shafts.
Old Jan 15, 2005 | 05:51 PM
Jim_C's Avatar
Jim_C
Bowtie67
Standard (non-adjustable) column - steering shaft overall length 37.49 inches.
Telescoping column - steering shaft overall length (in retracted position) 36.34 inches
- steering shaft overall length (in extended position) 39.345 inches.
CUL Jim
To '67 Steering Column........
