Gauging interest in selling correct 327/365 engine block, crank, heads.
I have a spare 327ci 870 casting block with 2680 crank that have been pressure tested and magnifluxed. Also a pair of 461 heads that were also magnifluxed. I was going to build the correct motor for my car but decided maybe a crate 383 would be better. The heads are bare and small valve so would need hogging out to 2.02/160 for better performance. The block is .008 to .010 at top worst area of cylinders so no problem going .030 bore. Dates are for block F 15 5 (june 17, 1965) heads F 16 5 and F 12 5 (June 16 and 12 1965). Heads have rocker studs only. My car build date is July 7, 1965 so I had the perfect motor but not numbers matching. I am tired of looking at it sit in the corner of my garage and maybe someone really would like to have it. What's it worth?
i have a spare 327ci 870 casting block with 2680 crank that have been pressure tested and magnifluxed. Also a pair of 461 heads that were also magnifluxed. I was going to build the correct motor for my car but decided maybe a crate 383 would be better. The heads are bare and small valve so would need hogging out to 2.02/160 for better performance. The block is .008 to .010 at top worst area of cylinders so no problem going .030 bore. Dates are for block f 15 5 (june 17, 1965) heads f 16 5 and f 12 5 (june 16 and 12 1965). Heads have rocker studs only. My car build date is july 7, 1965 so i had the perfect motor but not numbers matching. I am tired of looking at it sit in the corner of my garage and maybe someone really would like to have it. What's it worth?
Ken,
I saw that motor when I visited you and it was beautiful. If I was going to go with pseudo originality of my car, I would have wanted that one in my May 12, '65 car.
Maybe posting it in Craigslist Sac would generate interest locally and avoid shipping hassles. That's what I did with my '73 545 heads and they went the same day. I posted them here in the forum a few days before and no interest.
although the dates of these parts are close together which is nice you have to remember that these parts are not very rare at all.Although a 365hp motor could be built out of these parts the motor is NOT a 365hp motor.These also would have come in the v8 passenger cars of which there are many and there are plenty left over.In this case the dates kind of work against the value in the fact that they are dated late in the production.NCRS for example allows up to 6 months prior to build.These parts will not carry over into 1966 as the block casting# was last used in 1965.
here is one that recieved no bids on ebay at $300 it do not have any heads though
http://cgi.ebay.com/ebaymotors/327-C...1%7C240%3A1318
Received 1,847 Likes
This is what it boils down to. Never mind all that other stuff. How tired you get looking and how bad somebody wanting. Obviously, the right person hasn't seen your merchandise or you're not tired enough!
Otherwise, it has a tangible value of $.10/lb as noted.
Simple, really.
Paint the block and heads, put manifolds on it and put the thing on an engine stand. Make a display out of it and set it in your living room.
if I were in your position I would push it into the corner and if and when you ever go to sell the car it would be an asset to a prospective buyer.If you have the room.It does not eat anything as they say and as these things get older they tend to increase in value unlike my 401K
Ken,
Based on the production date of your block (June 17, 1965) then the only cars that could arguably benefit from the date-matching are 65 vettes built from late June until the end of the run.
If we use 1965 Production Data from Black Magic's web site, and assume the earliest vette that could have had a June 17 cast engine was built in approximately June 24, 1965 (I simply added a week to the casting date) then the earliest car in that scenario that could have used your engine is number 20657 and the latest 1965 corvette built was 23562.
Therefor one could argue that of the 23562 1965 Corvettes built, only 2905 could possibly use your motor.
This suggests to me that the value of your engine is more of an all-or-none proposition: It's just a small block vette engine to most prospective purchasers (little value), or a good date-matched engine for a very small handful of cars and an even smaller handful of prospective purchasers (a lot of value to what, 8, 10 people?).
Ken,
That is how I looked at it when I purchased it. You see all kinds of blocks and heads for sale. Yep, lots of 461 and 780s. But, do you find them with casting dates all within 4 days of each other? Would that not indicate an engine put together at the plant and not built in the junkyard? Would that not be of interest or value to someone who has a late June, July or even August car? Also could be used on the 350HP hydraulic cam motor and not just the 365HP. I believe the cam is the difference between the L79 and L76.
The block and heads could also be used for a 250-300 hp engine. They could be used in a Chevelle, Pass car. Those car groups look for dated components too.
Why do you dwell on the "junkyard engine" bit? That's what you have isn't? What is the difference between a factory built engine that's worn out, and component pieces of several factory engines that are worn out and sold as one group? The answer seems obvious, just curious why you brought it up?
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
PS Most of the posts about the value are right on sorry.
KEN
What was your point. You said gaging interest & what it's worth. You ask for it & got it. Why get your panties in a wad when people then give you there opining. You should have stated a price & then that would have been it. Remember Be careful what you ask for. You might get it.
KEN
KEN
My '65 has a July build date. Its running a 350 c.i.
The last engine that I had rebuilt about 8 years ago cost me $2500.00 for the machine work and building it. The cost of the parts, shipping, machine and build work would be a deal killer for me for a small block.
But, like you said, you may run across someone that can't live without it.
No offense but you are wrong. I had a 7 blade fan I offered for sale and asked value also here on this forum. I was told maybe $50-$90. I sold it with buy it now for $300. This forum is limited to those who look here. And the more time I spend here, the more I see comments made that get away from the subject. I was offered $1200 for it about a year ago by a forum member. I did not want to sell it then. So I was checking for interest and found NO interest so it's not for sale. I don't need the money. It will sit in the corner for another unknown amount of time until someone with the need wants it or I decide to build it myself. PS....You may wear panties, I wear boxers if ya have to know!
