Fresh Air Vent Assembly - 63-67
WTB - Fresh air vent assembly/passenger side for non A/C '67. Need all pieces: Cable, grill, valve assbly, vent door. What I have is just the oval fiberglass opening that this whole assembly fits into. Thanks!
St. Jude Donor '10
I'd do some checking before I bought anything. I tried to add the fresh air vent on a 67 a few months ago and could not get the parts through the existing hole. Apparently this part is installed before the front cap is put on. You will probably have to butcher the vent tube or the kick panel area. The main problem is that the vent door end is larger than the kick panel end. Not an easy job but it can be done.
