66 hazard warning assembly--how much?
Approximately what will a hazard warning light assembly with wiring harness cost me? How desirable are they?
1 Post
St. Jude Donor '10
I have picked up several of these (some from other GM products) over the last year or so and have managed to end up with two of them that are fully functional and are set up just as they should be with all of the correct parts and correct appearance. They have the correct 105Y133 flasher unit housings, correct old 1445 bulbs, correct handle/flasher, correct orange positive wire with correct connectors and pigtail, correct 170 Signal Stat flasher unit and finally correct harness with correct connectors that appear to have factory electrical tape wrapping. Both units have been plugged into my car and work great. I have not decided to sell one, but if you decide you may want one let me know. I will think up a price and send you some pics. I am afraid mine would have to be over $125 with all of the expense I have in getting them right. Just the correct period correct signal stat 170 is pretty pricey if you can get one.
