C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
WANTED Casting 772-58X heads
Old 07-30-2011, 06:28 PM
unclenasty
7th Gear
unclenasty's Avatar
Default WANTED Casting 772-58X heads
Desperately in need of a pair of heads for a 1958 FI casting numbers 3748772-58X....
HALP!
Old 07-30-2011, 09:11 PM
427390HP
Support Corvetteforum!
427390HP's Avatar
Do you mean 3748770? If so, my brother has a very nice date matched pair I think he will sell separate from a 58 engine he has.
If you're interested, send me an email to terryhaut@mchsi.com with your phone number and I'll have him call you right away.
Terry
Old 07-30-2011, 09:38 PM
unclenasty
7th Gear
unclenasty's Avatar
Hi Terry,
I think the 770 heads are the only ones that had the X58 casting for the FI engine. I am doing some research for a customer of mine and i now believe the 772 are for the 58-61 regular passenger cars and most likely even had the 2 bbl carb.
I was trying to also find info on just what the difference was between the 770's and a 3737739 that was also used in the 283, 57-62, Corvette, FI but doesn't have the X58....
Any thoughts?
Ben
Old 07-30-2011, 10:19 PM
427390HP
427390HP's Avatar
Ben,
There was only one head number for all 58 engines - 3748770. 3737739 was the block casting number for 58 and early 59 engines. No 57-62 Corvette engines had a 3737739 head casting number. I think you're mixing up block numbers with head numbers.
If you need a pair of heads correct for any 58 engine, whether it's a single 4BBL, dual quads, or FI, they have to be 3748770. There's no other number that would be correct. Naturally , other heads will work, but not be correct.
Terry
Old 07-30-2011, 10:30 PM
unclenasty
7th Gear
unclenasty's Avatar
Thanks for straightening out Terry!
Top Notch!
You wouldn't know where i could find valve specs for those heads would you?
Old 07-30-2011, 10:50 PM
427390HP
427390HP's Avatar
Yes, everything you need to know is in the Service Manual.
Old 07-31-2011, 08:32 AM
unclenasty
7th Gear
unclenasty's Avatar
Thanks again Jerry,
One last question. What do you think would cause the exhaust manifolds to get red hot within just a couple minutes of starting it up? Engine temp seems normal. Too much air getting in???....thanks a mil,,i really do appreciate it!
Ben
Old 07-31-2011, 05:11 PM
62corvette
62corvette's Avatar
[Timing way off will really heat up manifolds.QUOTE=unclenasty;1578279043]Thanks again Jerry,
Ben[/QUOTE]
Old 07-31-2011, 11:19 PM
relics6067
relics6067's Avatar
Default 770 X58 Heads
Unclenasty:
I have a set if you still need a pair. They are buried out in the shop (like everything else......) and have been for some time (like about 30 years............).
Let me know if I can help.
HTH
Old 05-11-2021, 07:19 PM
Rocky a
1st Gear
Rocky a's Avatar
Default 58 x heads
I have a set of 772-58x heads with new valves and springs
Old 05-18-2021, 11:50 PM
oldskydog
oldskydog's Avatar
772 heads were never used in production on Corvettes in 58. The 772 heads were used on 2 barrel pass car engines.
To WANTED Casting 772-58X heads
Quick Reply: WANTED Casting 772-58X heads
