FS: 1963-67 Convertible Vent Window Parts
I have 2 pairs of convertible vent window frames and some associated door and window parts. I had bought a pair of vent window frames to replace the heavily pitted frames on my ’67 but then subsequently found an even nicer pair to use (which I have now installed). The 2nd pair of frames listed below were removed from my ’67 and are heavily pitted from years of exposure to the coastal Florida salt air, which is reflected in the lower price. If you PM me your email address/cell phone# I will send detailed pics of any of the items below that interest you.
1) **SOLD** 1963-67 Convertible vent window frames. LH/RH pair. Pivot holes are good/not broken. Driver quality chrome with some light pitting.$250 $175 for the pair
2) **SOLD** 1963-67 Convertible vent window frames. LH/RH pair. Pivot holes are good/not broken. Chrome is heavily pitted. Original weather stripping is still present.$100 $50 for the pair
3) **SOLD** 1963-67 OEM Convertible vent window regulator. LH/Driver side. Worked well before I removed it from my ‘67. 1 ring on shaft (1-3/8" shaft length). $40
4) 1963-67 OEM Convertible vent window regulator. RH/Passenger side. Housing is cracked, but it still open/closed the vent window before I removed it from my ‘67. It spins a bit before it engages and moves the window, 2 rings on shaft (1-3/4" shaft length). $17.
5) **SOLD** 1967 Convertible inner door panel felt/fuzzys, new reproductions in unopened package. $30
6) **SOLD** 1963-67 OEM Convertible LH Wing Vent Window Glass Frames (I have 2 LH). Pivot pins and T-posts are in good condition on both. $85 each.
7) **SOLD** 1963-67 OEM Convertible RH Wing Vent Window Glass Frame. Pivot pin and T-post are in good condition on both. Comes with clear glass still installed. $85.
8) **SOLD** 1963-67 OEM Convertible RH Wing Vent Window Glass Frame. Pivot pin is broken off. T-post is in good condition. $25
9) **SOLD** 1963-67 Convertible vent window assembly to door installation hardware kit. Brand new in package from Paragon. $20
10) **SOLD** 1963-67 Convertible vent window vertical mounting bracket/rail. LH/RH pair. These are what the vent window rear weather-strip and side window run vertical fuzzies rivet to and attaches to the bottom of the door to hold the vent window assy in place. The stainless has a couple of dings and has some light scratching. $75 for the pair.
11) **SOLD** 1963-67 Convertible Front Window Run Fuzzies (pair). Reproductions. Vol Vettes Part# DR055. $15. Included for free if you buy Item #10 above.
12) Tinted vent window glass. $20.
I am willing ship the above at your expense if you are not local to me..
Last edited by AkrHack; 08-11-2019 at 06:56 AM. Reason: Update items that have sold
I've added a Convertible RH Wing Vent Window glass frame to the list above.
RH Vent Window glass frame.
Received 2,127 Likes
Check your PM for newly listed vent window frame. Dennis
One last ttt before Carlisle....
AkrHack....please bring the right side vent window glass frame to Carlisle. I'll be over in the '63-'67 Sting Ray registry area G. Dennis
To those of you who have contacted me about the vent window parts, note that I will be bringing them to Carlisle and will be there Thurs afternoon and all day Friday. If you want to see them first hand, send me a PM so we can arrange a time to meet.
ttt
Price drop for both pairs of Window frames.
