FS: Full set of c2 headlights w motors and tail lights
Full set of headlights, buckets, motors, wiring, mounting brackets, pivots etc.
Motors work but i would probably have them gone through before installing. Buckets are in very good cond, a couple of tabs are broken but bezels still mount with the u nuts.
tail lights are in very good condition with very light pitting. Lenses are in very good condition .
$1100. Plus shipping.
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
Do all the pivot ***** come off the shafts smoothly and are they in good shape? I don’t see all four of them. Do all four drives have the four screws into the buckets are any of those broken or cracked or stripped? Buckets straight? A lot of used ones are twisted. Are the bottom tabs for the headlight rim still the correct size for the original screws?
Headlights
All the ***** are there and in good condition.
buckets are straight, bezels are in good condition.
there is one missing tab and two broken tabs but the bezels mount fine and stay in place.
These came out of my 65 coupe and were working fine.
I tried to send this in private message but it will not go. The ball on the passenger side bucket appears to still be on under the blue tape does that slide off the shift properly? Can you send a better picture of the broken tab. Thanks
I might be interested in the headlight motors if you decide to split things up.
Craig
Craig
See PM
Check your PM about headlight motors.
Craig
Craig
