Nom = ?
Old Apr 4, 2005 | 08:38 AM
dsagers's Avatar
dsagers
Default Nom = ?
I see NOM used in descriptions for some cars by sellers. What does NOM mean?
Old Apr 4, 2005 | 08:43 AM
mandm1200's Avatar
mandm1200
Not Original Motor
Old Apr 4, 2005 | 08:46 AM
moosie982's Avatar
moosie982
Hi, NOM = Not Original Motor, thats it. Peace,,, Moosie
Old Apr 4, 2005 | 11:42 AM
platato's Avatar
platato
From: The Armpit of Illinois Platato says..... "Sometimes your the windshield & sometimes your the bug".
St. Jude Donor '05
You guys are mean
How about numbers matching
Check this thread out for more info http://forums.corvetteforum.com/show....php?t=1031378
STW!
Platato
Old Apr 4, 2005 | 02:38 PM
427basketcase's Avatar
427basketcase
Originally Posted by platato
You guys are mean
STW!
Platato
How do you get "Numbers matching" From NOM?
NOM= Not Original Motor
Old Apr 4, 2005 | 02:43 PM
CGGorman's Avatar
CGGorman
"No." is a common abbreviation for "Number"..."M" would then stand for "Matching".
That said, "NOM" is normally agreed to mean "Non-Original Motor"
If a person has a numbers matching car, they ususally take the extra time to make it obvious...
Old Apr 4, 2005 | 02:44 PM
68shark's Avatar
68shark
Agree....of course, there is NOM and NOM. One can mean any engine other than the original. For example, replacing a 427/435HP engine with a 454 truck motor is not the same as replacing with a correct casting number, date coded replacement block with most other parts retained or replaced with correct components.
Both are "NOM", but one likely decreases the value of the car less than the other.
Old Apr 4, 2005 | 10:14 PM
platato's Avatar
platato
St. Jude Donor '05
Ummmmm, guess I should have said I live in southern Illinois, we do things a little different down here (1/2 of these people still have couches on the porch). I have heard it used both ways so it's probably good to make sure with the seller or better yet check it out yourself
STW!
Platato
Old Apr 5, 2005 | 12:43 AM
Tom73's Avatar
Tom73
How about No Match ????
The general and accepted use of NOM is Not Original Motor.
tom...
To Nom = ?
