Whats the difference in Wheel Backspace and Offset
Old Apr 5, 2005 | 09:04 PM
BreauxBridgeKid's Avatar
BreauxBridgeKid
Default Whats the difference in Wheel Backspace and Offset
I am about to purchase a set of 17x8 with 4" backspacing but was reading something about offset...I wanna make sure I dont buy the wrong ones...anything else I need to know before buying?
Old Apr 5, 2005 | 09:07 PM
kdf1986's Avatar
kdf1986
Hello,
Here is a good article on wheel backspacing and offset.
http://www.usacomp.com/Offset.htm
From this website I cut and pasted one of the paragraphs below.
kdf
So what are offset and backspace? Offset is the distance from the Centerline of the wheel to the wheel bolt up face (the part of the wheel that contacts the car's hub when you attach the wheel). Positive or Negative is the descriptive term that tells us whether the wheel bolt up face is farther towards the inner or outer part of the wheel. Defining which side positive or negative means is the part not everyone agrees with. Backspace is not near as confusing. Backspace is the distance from the edge of the inner rim to the wheel bolt up face.
Old Apr 5, 2005 | 09:24 PM
BreauxBridgeKid
So what else do I need to know other than I need 17x8 with 4" backspace when ordering them?
Old Apr 5, 2005 | 09:54 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Well, you need to know if the wheels will clear the C3 calipers.. None of the specs will tell you that... The best way is to check if others are using the same wheels and if they fit without spacers... If you need to add spacers you'll need add the size of the spacers to the needed backspacing.. For example.. if you need a 1/2 inch spacer to clear the calipers, you'll need 4.5 inch backspacing instead of 4 inches for the identical fit...
Old Apr 5, 2005 | 11:31 PM
MN-Brent's Avatar
MN-Brent
What wheels you buying?
Old Apr 6, 2005 | 02:11 AM
BreauxBridgeKid
The Omi-Potent Ever Powerful, Torq Thrust 2's from American Racing
Old Apr 6, 2005 | 10:20 AM
GrandSportC3
Those wheels should clear the calipers and 4 inch backspacing will work just fine... (I always thought that those wheels had 3.875 inches backspacing... Either way it should work fine..
Old Apr 6, 2005 | 12:27 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
The TTIIs have 4" backspacing and around 11mm of offset. They fit perfect on C3s.
These are what I have and they fit perfect.
American Racing Torque Thrust 2 Wheel (Part Number 505-7861)
To Whats the difference in Wheel Backspace and Offset
