I have them on my 69 B/B . I replace them about every 3yrs because if you let the car set for a long time they will stsrt leaking. Advance has the with a life time replacement . I use synthic brake fluid.
I think my AutoZone calippers are Cardones..... no problems so far except a stripped thread (it was stripped when I took the caliper out of the box)
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I did find that the cross bolts in the calipers are not torqued to factory specs when I was tearing the Cardone calipers down to put in O-ring pistons.
I did contact Cardone today to see if the calipers are stainless steel
sleeved and they said they are. This is not mentioned on Advance
Auto parts web site nor on Cardone's web site.
The calipers that Auto Zone carries are from Fenco, which are stainless
steel sleeved acording to their web site.
One other interesting thing I found out is the warranty on the Cardone's. According to their web site, they have a lifetime warranty
to the original purchaser on the original vehicle. It says to bring the
calipers back to the store purchased for the warranty. According to
several sales people at Advance Auto parts, they only replace the
calipers once under warranty. Would be interesting if anyone would
clarify the warranty with their local Advance Auto parts store.
I have replaced my 2 times , Advance doesn"t give me any hassle they take the old ones and I get new ones . Life time warrenty verses limited life time is the answer
