Custom Side Pipes
Old Apr 7, 2005 | 10:48 PM
1980 454's Avatar
1980 454
Default Custom Side Pipes
IM GOING TO TAKE FOUR 2 " PIPES SQUARE THEM UP AND TWIST ALL FOUR INTO A SPIRAL I PLAN ON USING CASTING SAND PACKED IN THE PIPES THEN TACK THE PIPES ONTO A SIZEMIC DRILL BIT HEAT AND BEND GRADUALLY INTO A SPIRAL PULL THEM ALL APART AND SPACE .25 APART FROM EACHOTHER GIVING ME A CUSTOM SET OF THE WICKEDEST THING IVE BUILT THIS WEEK.WILL POST PICKS.MIGHT CATCH ON.. OH YAH I LIVE IN ALBERTA CANADA NOT TO MANY PROBLEMS WITH THE COPS IVE BEEN RUNNING STRAIGHT PIPE SIDE MOUNTS FOR 2 YEARS WITHOUT ANY HASSLE BUT WHEN I GO TO THE COAST THIS SUMMER ILL PROBABLY HALF TO DISCONNECT AND MODIFY MY OLD EXHUAST TO MEET B.C. SPECS THEY WOULD PROBABLY TOW ER ON ME AND ONLY THE newfees FROM THE EAST COAST finish every sentince with eh!canadas mississippi oh son!
Old Apr 8, 2005 | 09:27 AM
CGGorman's Avatar
CGGorman
You sound really EXCITED about it! Hope it works out for ya, eh.
Old Apr 8, 2005 | 09:40 PM
1980 454's Avatar
1980 454
it will work just like my propetual motion machine..son! do you have a skirt to go with those nice earings!
Old Apr 9, 2005 | 08:29 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
eh!
Old Apr 9, 2005 | 10:57 AM
1Bad69's Avatar
1Bad69
Do you have a dictionary to go with that grammar?
What is the O.D. of the pipes going to be when you twist them together?
Old Apr 9, 2005 | 11:25 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Old Apr 9, 2005 | 01:38 PM
Twin_Turbo's Avatar
Twin_Turbo
cough ..perpetual..cough.
Old Apr 9, 2005 | 03:16 PM
hubes's Avatar
hubes
post some pics when ur done, oh and btw, the only people Ive met who say eh are from ontario
Old Apr 10, 2005 | 12:16 AM
1980 454's Avatar
1980 454
the pipes will be 4.25 approx .thanks for correcting my spelling some three nano seconds must have past between my brian and my fingers.you are commended for siezing that brief window of opportunity..this has caused me to rethink my errant spelling mistakes no more will our conversations be blighted by these unpleasant incidents for i am restructuring my brain to slow down and make sure i look at the keys instead of the screen.
Old Apr 10, 2005 | 12:48 AM
Jclgodale3's Avatar
Jclgodale3
better slow down "some more"
between my brian and my fingers?
Old Apr 10, 2005 | 06:12 AM
WESCH's Avatar
WESCH
Hi
Do you mean one complete twist of the 4 tubes ? So basically straight out tubes with no inserts at all.
You must post some pics of this. I just can't imagine the looks of this, may be with a heat shield mounted.
Good luck. Günther
Old Apr 10, 2005 | 08:01 PM
1980 454's Avatar
1980 454
THE PIPES WILL CONSIST OF FOUR PIPES PUT TOGETHER LIKE SO [ ] THEN TWIST ALL FOUR INTO A SPIRAL RAN RIGHT OFF THE SIDE MOUNT HEADERS NO INSERTS WIDE OPEN (STRIAGHT) PIPES CHROMED UP WITH NO HEAT SHEILD IT WOULD HIDE THE EFFECT OF THE CUSTOM BLING.
Old Apr 11, 2005 | 12:17 AM
Schmucker's Avatar
Schmucker
Yeah, I thought of that, then I thought it might look okay, but I decided that it would be beneficial feeding all the exhaust gases into one tube rather than splitting them like that.
Old Apr 11, 2005 | 06:48 AM
WESCH's Avatar
WESCH
Hi
Won't you loose power exhausting each cylinder individually ?
I thought that the previous exhausted cylinder exhaust draft helps sucking the next exhausting cylinder empty and so on.
That's why headers need specific lenght tubes .
Günther
Old Apr 11, 2005 | 11:39 AM
CGGorman's Avatar
CGGorman
Old Apr 11, 2005 | 12:01 PM
HYPER65's Avatar
HYPER65
Don't make the I.D. bigger than the O.D. or the hole will be on the outside.
Old Apr 11, 2005 | 03:16 PM
Pauld's Avatar
Pauld
Originally Posted by AGVI
A comma here and there might help too, pretty hard to read these postes
To Custom Side Pipes
Old Apr 11, 2005 | 04:11 PM
AV8RSVT's Avatar
AV8RSVT
Need Pic's!!
Gary
Old Apr 11, 2005 | 04:23 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Originally Posted by AV8RSVT
Need Pic's!!
Gary
Old Apr 11, 2005 | 04:30 PM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
anyone got any advil? all that yelling and bad grammar gave me a headache
But I am still curious as to what these beasts of some pipes are going to look like, keep us posted (and turn off your caps lock please)
