engine id
Old Apr 10, 2005 | 04:45 PM
tilyn62's Avatar
tilyn62
Default engine id
The motor is an 454 that had the peanut port heads on it and it had a 50 cent size dish in the piston the block says hi perf on it. Also we asked the machine shop what it might be and he said it was a heavy duty truck motor with the forged pistons, and crank and 4 bolt mains. I want to know if any of you have had seen these engines or heard of them. Also want to know what your opinion is. We only disassembled the top end of the engine.
Old Apr 10, 2005 | 04:52 PM
Tom73's Avatar
Tom73
What are the numbers?
Old Apr 10, 2005 | 05:02 PM
tilyn62's Avatar
tilyn62
where are the numbers located on the block.
Old Apr 10, 2005 | 05:03 PM
tilyn62's Avatar
tilyn62
where or the block castings numbers located?
Old Apr 10, 2005 | 05:27 PM
tilyn62's Avatar
tilyn62
the numbers are 14015445.
Old Apr 10, 2005 | 06:06 PM
screamin340's Avatar
screamin340
3rd Gear
Default From Mortec
14015445...454.......78-90...2 or 4 bolt
On the front passenger side block deck just infront of the head are more numbers those will help also...unless the deck has been milled
To engine id
