Cleaning Your Belly
Old Apr 11, 2005 | 07:04 PM
NHvette's Avatar
NHvette
Default Cleaning Your Belly
I know it was covered recently, but I just finished up cleaning my belly.
That is: the underside of the body.
I hope this isn't too technical for C3Gen.
It really wasn't TOO bad for a few decades of grimey buildup.
The worst was near the differential. Sorry, but I did not have my camera
at hand when I first started this job. So, no greasy pics.
First thing I did was to get better access. Yeah - I built my body dolly
fairly high, but I wanted more - plus room to hit at a good angle with
the power washer. So, I hooked the back of the body dolly onto my
gantry crane and lifted the butt end up-up-up.
I wanted to try the oven cleaner, but I didn't want to drive to the store.
I had a couple gallons of Castrol SuperClean. Using a spray bottle, I sprayed
down the entire bottom with cleaner ... let it soak in. About an hour later,
I gave it a quick re-spray and scraped as much off as I could with a
sheetrock taping knife. A medium sized putty knife would work better.
After scraping, I fired up the power washer and blasted the whole belly.
The next step was easiest: go inside and continue in the morning when I can see good.
The next day revealed that there were still patches and areas of stuck-on
grime. So, I gave it a quick scraping in the worst areas and started from
the front ... spraying with 100% Superclean and using a scrub-brush.
Be careful to wear gloves and don't breathe in the cleaner (choke-cough).
After going over the whole bottom with cleaner and brush, I fired up the
power washer again ... and that did the trick. There are a couple of corners
that I missed, but it is "Super Clean".
Here are some more pics: First set is after cleaning ... second set after
applying POR-15 to all the metal pieces under the body.
http://NHvette.com/ftp/in/vette_body/clean_belly_01.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_02.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_03.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_04.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_05.jpg
The inside needs a good cleaning ... that's next.
http://NHvette.com/ftp/in/vette_body/clean_belly_06.jpg
Belly with POR:
http://NHvette.com/ftp/in/vette_body/clean_belly_07.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_08.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_09.jpg
http://NHvette.com/ftp/in/vette_body/clean_belly_10.jpg
That's all for now ... lots of little do-dads getting cleaned up and installed,
like this rag joint that came as a new part with my 75 vette about 10 years ago.
"I'll install that someday." Someday finally came.
http://NHvette.com/ftp/in/rag_joint_rebuilt.jpg
She won't be "done", but I will be driving her ... come June.
Old Apr 11, 2005 | 07:29 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
they're never "done"
best of luck with the project.. I know you've been at this for a while
hope you enjoy that first drive come june
Old Apr 11, 2005 | 07:40 PM
comp's Avatar
comp
thanks for the pic's
Old Apr 11, 2005 | 09:24 PM
rihwoods's Avatar
rihwoods
What kind of power washer do you have ?
Old Apr 11, 2005 | 09:40 PM
wills670's Avatar
wills670
looks good. i have been cleaning mine with gasoline soaked rags. i plan on leaveing mine natural finish on the under side. glad to see someone else going thru the same trouble. i have ask myself am i crazy. keep going it will end sometime hopefully.
Old Apr 11, 2005 | 09:53 PM
rosslato's Avatar
rosslato
that is what i call a super clean shell. don't stop there with the por-15, do the whole shell with it, it looks great, protects and it's on there forever. i used the black on mine
Old Apr 11, 2005 | 10:01 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
NHVette,
Pulled the body on my 1970 this weekend and started cleaning the underside tonight.
Did you have tar buildup in any of the wheel wells? My DS front has a ton of tar buildup which seems to only want to come off with a chisel.
Old Apr 11, 2005 | 10:20 PM
PRNDL's Avatar
PRNDL
did you get one of those orange gates from Central Park??
Old Apr 11, 2005 | 10:42 PM
wills670's Avatar
wills670
Originally Posted by gearheaddroppings
NHVette,
gearhead, that is why i used gasoline soaked rags to clean mine. some one had undercoating/tar everywhere and it was the best thing that i found to clean it with and not do any damage to the fiberglass.
Old Apr 12, 2005 | 10:56 AM
NHvette's Avatar
NHvette
Yeah - the factory undercoating was on there very well.
I left it there and scrubbed it clean. Later, it will get blacked
out in the wheel well areas with a can of Krylon or maybe another
layer of undercoating.
I have a fairly cheap power washer from Sears. I like it:
They go on sale occasionally for like $239
http://www.sears.com/sr/javasr/produ...Washers%2C+Gas
Old Apr 12, 2005 | 03:41 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Thanks for the post. I always look forward to seeing pictures of your progress. Getting this car back on the road is a pretty incredible achievment.
Old Apr 12, 2005 | 04:43 PM
CGGorman's Avatar
CGGorman
I bet it's cleaner now than the day it was born! Nice work.
Now, where's the pic of you wearing the environment suit, totally covered in sludge?
Old Apr 12, 2005 | 04:52 PM
NHvette's Avatar
NHvette
Actually, not too bad. Two pairs of pants with totally BLACK knees and
many pairs of nitrile gloves.
What bothered me the most was getting spattered in the face with POR15
as I rushed to get it all coated.
I got it all off before it hardened ... woulda been hell going back to work
with little silver specks all over my face.
To Cleaning Your Belly
