bird cages
Old Apr 14, 2005 | 11:32 PM
teebone's Avatar
teebone
8th Gear
Default bird cages
Needing a bird cage for a '69, what years will fit? 68-77?
Old Apr 15, 2005 | 09:11 AM
cosmicvette's Avatar
cosmicvette
Does anyone have photo's of the 'birdcage' I am intrigued to see what they look like.
Are they a structural component tied into the chassis/suspension or do they just supply strength/structure to the fibreglass body?
cosmicvette
Old Apr 15, 2005 | 09:17 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
from Tom73's site
Old Apr 15, 2005 | 10:26 AM
Ganey's Avatar
Ganey
Yes.
Originally Posted by cosmicvette
Are they a structural component tied into the chassis/suspension ...
cosmicvette
Structural, like a roll cage. I talked to a guy that rolled a 76 at near a hundred & was fine- he was wearing the belt.
Old Apr 15, 2005 | 12:04 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
cosmicvette
It provides a "backbone" for the fibreglass. It doesn't too nearly enough to make the chassis rigid. With flexible body mounts it would do even less. The coupes are noticeably more rigid then a Vert.
Only way to make the chassis/suspension more rigid is to weld in a roll bar and make the frame a "3D" structure vice the "2D" the frame currently is.
Old Apr 15, 2005 | 02:07 PM
teebone's Avatar
teebone
8th Gear
So does anyone know the years that trade-out or can you point me to a source that may.
I have been told that the 68-77 will interchange but I want to make sure before I start shopping. As if it actually extends to '82 that is better me, if it does stop at 77 that is still good for me, if it stops at 73 or something then that is bad for me.
Old Apr 15, 2005 | 04:24 PM
Corz's Avatar
Corz
it's identical to a 77.. i'm pretty sure its the same for an 82 but not positive
Old Apr 16, 2005 | 11:46 PM
MikeC's Avatar
MikeC
There was a change in the 78 model due to the different dash. Its just the piece at the base of the windshield. Drilling a few spot welds and welding on the old part wouldn't be much work.
Old Apr 17, 2005 | 10:34 PM
teebone's Avatar
teebone
8th Gear
Thanks for the help.
I scored a late 76 or early 77 (single pin visor) rear clip yesterday. Now the fun begins.
Old Apr 18, 2005 | 01:51 AM
cosmicvette
Good luck, keep us updated with pics!
And thanks for the info re bird-cages everyone, another question answered..........another million to go.
cosmicvette
Old Apr 18, 2005 | 11:31 AM
67tripwr's Avatar
67tripwr
Default bird cages
The only cages I will mess with any more are real animal ones! This sounds like a nightmare for sure! I have seen some real roaches over the years.
Old May 6, 2005 | 08:58 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Teebone. What are you going to do with the VIN? Are you using the title for the New bird cage's VIN or are you going use your OLD/current VIN and title????
Old May 6, 2005 | 10:03 AM
Twin_Turbo's Avatar
Twin_Turbo
the birdcage is nothing like a rollcage, it isn't even as " structural" as you may think, basically it holds the doors in place and the windshield up. The crash protection is poor, the cage consists of stamped sections spot welded together. The majority of the car's stiffness comes from the ladder frame and since ladder frames have poor torsional stabilit and like to twist our cars do that also. I would not want to roll my car, if you rolled it hard and walked away from it you're pretty lucky, the rolling must have kept the entire weight of the car from being excerted on the cage, if you would take a vette, turn it upside down and drop it I'm willing to bet a fair amount of beer that the entire top will be flat. I saw one vette that rolled into a ditch and the portion above the door handles was next to non existent, completely flattened.
To bird cages
