C3 Suspension Sucks!
I've replaced the shocks. What else can be done for a more comfortable ride?
Do the rebuild kits actually make that much of a difference?
Any before and after comparisons would be appreciated.
Thanks, Les
handles like its on rails
complete new suspensionwith billsteins, and a dual mount. Your biggest mistake would be
to put a mono up front. Good luck
here that has been in my car more than once, and cannot believe how smooth it is.
The 550lbs coils and the Bilstein shocks are awesome.... safe your money and buy the fiberglass spring later... first see if you're happy with the steel spring
...you're gonna let me drive your car? oh no...I can see it now! I'm gonna want a big small block! OH NO!!!!
Something must be non-stock on your car. Or by any chance do you have a 7-leaf rear spring? Go take a look...
BTW: It could also be all those lousy frost-heaved roads in Ontari-ari-ari-o!
j/k
It, and all the other mods I did, otherwise similar to Megladon's, makes it an incredibly solid suspension, but it is very, very harsh. I always preferred that.
It depends on how you want it to drive. The coils will give it a better ride quality to the driver, but the monoleaf will make it even firmer. Either setup is great and will stop your car from bottoming out while giving you better control. My new oil pan is literally less than 3" off the ground but I haven't hit it yet on the worst potholed roads you can imagine (yes, I do need to rig a plate, if I can figure out how on this one....)
I also went with the largest diameter fore and aft sway bars I could find - both a diameter larger than that offered in the full VBP kit. I think my front is 1.25" and the rear is 0.875". Other than that I have the full monster deluxe triple thrown down VBP kit. I have both front and rear springs set one notch from maximum. I don't recall which shocks are on there from the last change.
Aside from getting some much stiffer sidewall 17" wheels, needed for speed ratings anyhow, my main suspension is one of the few areas done. Of course when I finish off the Tom's Diff rear suspension with their 1480 max thickness axle kits with offset trailing arms (and somebody's 6 link conversion) I will have to alter the rear suspension a little. (We'll ignore the whole disconnected power steering system for now...
EXACTLY
, the front mono is for Auto X only. I guess itsall in what people choose for a ride, I did mine for a daily driver type
setup. very smooth, but not bouncy,or boat like ride, and remeber,
I have small side wall tires, so that helps with the rail, type grip affect.
275/40's and 315/35's
Thanks, Les
