Getting Sill Plate Screws out - Help!
Old Apr 30, 2005 | 11:24 AM
69L71's Avatar
69L71
Default Getting Sill Plate Screws out - Help!
I'm installing new carpets in my 68 convertible. So far it's been a piece of cake, except that I can't get the 8 screws that hold the sill plates out (4 each). They immediately stripped when I used a scewdriver. Then I took a dremel and cut a notch so I could use a blade screwdriver. No good. Then I bought an easy-out and a 5/32 cobalt drill bit. I'm getting nowhere drilling the screws. I'm running out of ideas.... I also don't want to totally destroy the sills. They're in decent shape.
Thoughts?
Old Apr 30, 2005 | 11:37 AM
Jclgodale3's Avatar
Jclgodale3
I would drill the heads off...let the shank fall through. I bought new screws and pushed some of those plastic (very small) sheetrock type anchors in the fiberglass holes and used new screws to re-apply. Pulled em down nice and tight!
Old Apr 30, 2005 | 12:52 PM
kdf1986's Avatar
kdf1986
At this point you may have to drill the head of the screws out so that the sill plate will lift off over them, then use a pair of pliers or visegrips to unscrew them once the sill plate is off.
Replacement sill plates are $20 each if they get too scratched up from doing this.
kdf
Old May 2, 2005 | 11:13 AM
69L71's Avatar
69L71
Thanks for the advice. I dodged the bullet alltogether for now. I was able to pull the old carpet out and wedge the new one up under the sills without removing them. It came out great.
I'll save pulling the sills for another day. Many years from now...
Old May 2, 2005 | 11:38 AM
Stewart's74's Avatar
Stewart's74
Well I see you got the job done....I had to drill mine out......
Old May 2, 2005 | 12:20 PM
LT4Coupe's Avatar
LT4Coupe
I would try a little JB Weld on the head of each screw. Then
place a thin metal object (a small nail?) on the head. When the
glue dries (about 24 hrs.), you shoud be able to use the nail
which you've glued to the screw to pull up on the screw
(while unscrewing).
Old May 2, 2005 | 04:30 PM
Edzred72's Avatar
Edzred72
That's what I did, but to repair hogged out holes.
Eddie
Old May 2, 2005 | 05:03 PM
CGGorman's Avatar
CGGorman
Old May 2, 2005 | 06:40 PM
jpatrick636's Avatar
jpatrick636
CGGorman,
Do you do a show called Tool Time?
To Getting Sill Plate Screws out - Help!
