air pressure
Old May 1, 2005 | 08:22 AM
WALTER51's Avatar
WALTER51
Default air pressure
What Is Correct Air Pressure For Tires On 1979 Vette Stock
Old May 1, 2005 | 08:53 AM
rihwoods's Avatar
rihwoods
32 PSI for both 225-70-15's and optional 255-60-15's including temporary spare 195-80-15.
Old May 1, 2005 | 09:00 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why do you suppose on my 77 they have a door decal that says 20 front and 26 rear? its seems awfully low.
Old May 1, 2005 | 09:04 AM
WALTER51's Avatar
WALTER51
mine says 30 front and 35 rear then another sticker says 20 front and 26 rear
Old May 1, 2005 | 09:28 AM
GDaina's Avatar
GDaina
lower air pressure will give a softer ride...best all around pressure IMHO is 32
Old May 1, 2005 | 09:34 AM
bobs77vet's Avatar
bobs77vet
thats TWO funny.....
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Could it be because of bias ply tires? I don't know when radials came out.
Old May 1, 2005 | 10:06 AM
GDaina's Avatar
GDaina
YUP
MID 70'S...
Old May 1, 2005 | 10:07 AM
rihwoods's Avatar
rihwoods
Read section 5 of the owners manual.For 78,they are refering to load range"B" radial tires.
But in no way would I run 20 PSI on the front for street.Not even 25.
32 PSI works good and allows for increases of 4-6 PSI for sustained driving which occurs when tires heat up.
Autocross is another matter. I used to start with 34 front,32 rear.
Old May 1, 2005 | 10:22 AM
bobs77vet's Avatar
bobs77vet
not that i'm endorsing this..... only reporting what the owners manual says....77 does have radial tires on it and yup 20lbs front 26 rear
Old May 1, 2005 | 11:55 AM
rihwoods's Avatar
rihwoods
Yep.My placard says same.But what "comfort" is there running tires under inflated ??? Reminds me of the Ford Explorer/Firestone fiasco.Heh.
Old May 1, 2005 | 07:48 PM
carl a's Avatar
carl a
they came out with the 73 model year
Old May 1, 2005 | 09:19 PM
greyghost79's Avatar
greyghost79
been looking for the "correct" spare for the 79. 195-80-15?? what kind of rim was that on??? a little donut spare? or something else? where can i find one?
Old May 1, 2005 | 09:23 PM
rihwoods's Avatar
rihwoods
Steel rim.15 ". You can fit a 205-70-15,if you want.
Old May 1, 2005 | 09:27 PM
Bangkok Dean's Avatar
Bangkok Dean
That is what I have also.
Old May 1, 2005 | 10:40 PM
greyghost79
steel rim. like the steel rallye wheel?? so it's not a "donut" spare?
To air pressure
