C3 performance Here...1/4 mile, MPH, etc
Old May 1, 2005 | 03:48 PM
holley505's Avatar
holley505
Default C3 performance Here...1/4 mile, MPH, etc
Hey guys just curious on current C3 performance on this webpage. I know there are a few BIg hitting out here 11 and 10 1/4 times.
See if you can follow this format.
77 vette
L48 standard bore
Th350
3.36 gear
edelbrock performer Intake
Mid america true dual exhaust
2400 stall
no weight reduction
15.2 at 98 mph best time
sea level (Florida)
Lets see what you guys are running currently.
Old May 1, 2005 | 04:04 PM
LiveandLetDrive's Avatar
LiveandLetDrive
1977 L48 Coupe
350 ci
th350
Edelbrock Performer
stock Q-Jet
CompCams 268HE
Hooker headers
2" badly made exhaust
3300lbs
3.08 gears
14.957 @ low 93 something... I think
Heartland Park Topeka, KS
In any case I'll have to update this in two weeks after my first Cruise In. I was still sucking through stock heads back then... New setup is still "teething." Could the Lars Tuning for Beer event one week before have been better timed??
-Chris
Old May 1, 2005 | 06:02 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
11.05 @ 121 mph
Naturally aspired small block, street driven...
Old May 1, 2005 | 07:16 PM
VETDRMS's Avatar
VETDRMS
74 Coupe
406SBC
Ported AFR 195 heads
10.7:1 Compression
Comp XR280R Solid Roller
Victor Jr. Intake
2.5" Dual exhaust with H-pipe
Dynomax Ultra-Flo Mufflers
TH-400
4200rpm stall
3.55 rear gear
245/45/17 Kumho street tires
3600 lbs
4000ft elevation
11.74 @ 116.08
NHRA corrected ET/MPH: 11.16 @ 122
Old May 1, 2005 | 07:34 PM
GrandSportC3
As I mentioned in my PM...
Come to the National Corvette Challenge during the Corvette Forum Cruise in in 3 weeks!! The weather hopefully won't be too hot and the elevation is about 600 feet there
Would love to see that beast run and maybe get a chance to run against you!! That would be fun and would make a awsome C3 video!!
Old May 1, 2005 | 08:18 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
i havent run m c3 yet but i did run my c2
66 coupe
427
stock
stock
stock
stock
straight exhaust
4 speed muncie
3.73 rear gear
i have no clue what it weighs or the elvation it was at bradenton motorspeedway.
it was in the 14's im not sure of the speed but i couldn't get the tires to hook.
Old May 1, 2005 | 08:29 PM
GrandSportC3
66 coupe
427
stock
stock
stock
stock
straight exhaust
4 speed muncie
3.73 rear gear
You gotta come out for the Corvette Challenge in 2 weeks in Bradenton!!
Old May 1, 2005 | 08:45 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
my 73 should be done all i ahve to do is pick up my heads and get an intake and measure the clearences in my rods.i have slicks on all 4 tires though.i dont think it will go that fast in thequarter becuase i didnt make it for torque.
Old May 1, 2005 | 08:57 PM
GrandSportC3
Slicks on all 4 tires
Is it a road race setup or are you talking about front skinnies?? I've never seen anybody with slicks in front!!
Old May 1, 2005 | 09:17 PM
oregonsharkman's Avatar
oregonsharkman
76 coupe:
AR Racing 383 stroker...440hp/448 tq
4-speed BW w/ hurst comp+ shifter
3:36 rear!!!
<3000 lbs--(lotsa stripping and aluminum parts---intake/carb/heads/starter/alt/radiator/dual 11" spals/)
cerama-coat headers w/ custom 2.5" duals and flowmaster 40's
radio/speaker/carpet pad/AC/pwr windows/doors and other stuff delete
no drag strip passes YET!!
but a friends g-force says 12.9 @ 111 MPH.....(street tires w/ loads of smoke)......
Old May 1, 2005 | 09:37 PM
ZL1powr's Avatar
ZL1powr
71 Vette
ZL-1 4.28 bore x 4.25 stroke (489.3 ci)
Richmond 6 spd w / 2.77 1st
3.70 rear
Edelbrock Victor Jr. CNC rectangular port heads
Edelbrock Performer RPM Intake
Comp Cams 288AR-10 cam
Weight=?
BFG TA street tires (275 rear and 255 front)
Hooker Sidepipes with muflers
11.615 sec @ 125.73 MPH with 1.98 sec 60'
Old May 1, 2005 | 09:42 PM
PRNDL's Avatar
PRNDL
68 vert
L36 original engine (427/390 hp gross factory rating)
M20 (wide ratio 4 spd)
3.36 gear
stock intake - edelbrock 1901 Qjet replacement (similar to stock)
Hooker supercomp headers/ flowmaster 50 mufflers
no weight reduction
13.5? @106 mph
original engine mostly stock configuration.
Old May 1, 2005 | 10:32 PM
sidepipes79's Avatar
sidepipes79
79 L48
new crate engine from put in in 1993 (performance unknown)
3.08 rear end.
14.2 @95
Old May 1, 2005 | 10:35 PM
Glensgages's Avatar
Glensgages
holley 505:
Your rear-gear is killing your ET.....
4.11s and something-sticky would get you into the low-14s easily, as a 98-MPH trap-speed should be very close to the 13-second mark.
Old May 1, 2005 | 10:51 PM
litevette's Avatar
litevette
69 coupe
350
th400 (rebuilt stock)
Edelbrock aluminum heads & intake
600 cfm carb
hooker headers
Much shaved weight
electric fans
reductioin pulleys
msd hei
crane cam
stock gears?
2200 stall
lucky keychain
12.7 @ 109
Old May 1, 2005 | 11:33 PM
wildman378's Avatar
wildman378
Originally Posted by PRNDL
68 vert
3.36 gear
no weight reduction
13.5? @106 mph
wow nice time for a stock l36 I better watch my dad then because my 95 didn't do but a 13.2 @ 104-105 and his is a l36 68.
great time
Old May 2, 2005 | 12:42 AM
Solid LT1's Avatar
Solid LT1
72 LT-1
factory intake with 650CFM double-pumper
M-22, 4.56 gears, Hoosier 9.5"X26-15 slicks
12.28@117MPH at Vette Magic in Sacramento, CA 3 years ago, Last year and 6K miles later: 12.48@115MPH without the skinny "front runner" tires on 15X3.5" wide wheels (my buddy said those should easily be worth 0.25 seconds improvement compared to my 275-50-15 autocross tires on 15X9" wheels.)
To C3 performance Here...1/4 mile, MPH, etc
Old May 2, 2005 | 06:42 AM
holley505's Avatar
holley505
I am hoping to run mid to high 12 with MY LS1 motor.
That should be complete within the next 2 weeks.
I am guessing 12.6 at 113mph that would be great!
I would love to make the corvette challenge in Bradenton florida.
GREAT post lets keep in coming....
Old May 2, 2005 | 07:42 AM
Gordonm's Avatar
Gordonm
Its all in my signature
Old May 2, 2005 | 09:20 AM
SpyderD's Avatar
SpyderD
1981 w/recon'd old 4 bolt 350 block, bored to 355, flat top forged pistons
700r4
3.7 gears
Edelbrock Performer RPM intake
L98 Heads
Comp Cams 280
Custom Dual exhaust, unknown brand headers
Stall - 2000(?)
13.03 @107.5 @ Memphis Motorsports Park
