Track times for c3's
I was just curious as to what kinda times you guys are getting with x amount of horsepower . Please list trans and gear. A friend and i just took his c3 to the chasis dyno and made 359RWHP with his 350. we cant get to track for a few days and want to know what to expect.
Thanks in advance
john
Thanks in advance
john
11.05 @ 121 mph was my best.. Don't know what RWHP...
With 395 RWHP he should be in the 11's with decent traction and gearing.. Gearing is the key!
Originally Posted by Les
359 RWHP should get him into the low-mid twelves assuming he can hook it up.
I ran 11.67 with 365 RWHP and 5-speed tranny...
(that was with my old engine)
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I have a stock ZZ4 engine (probably 300 HP at the crank) and get 14.07 in the 1/4 mile with a lot of tire spin. I can't get a sub 2.0 sixty foot time. Using a 700R4 and 3.73 rear gears.
It would be a 13.8 car with drag radials. That puts me right in with the stock C5's and LT4 C4's.
Originally Posted by BrandonS
Do you get alot of wheel spin? 12.9 seems slow for that much hp and such little weight, especially matched to a 4spd.
1 Post
Originally Posted by GrandSportC3
It all depends on the setup..
that is now MY 383. Same motor, smaller headers and exhaust, full MSD ignition in an 3680 lb car loaded with 3.36 gears, tight 1800 stall convertor. 12.9
Olivier's car has 3.70's with a 5 speed and weighed only 3200 loaded.
My car again as above with my L48 warmed up with a cam, headers and carb, 14.6
Using 360 RWHP, I calculated some 1/4-mile MPH, based on various weights (ET is a function of traction and gearing, while MPH is indicative of HP/weight), and here is what I found:
3800 pounds = 111.22 trap-speed
3600 pounds = 113.54 trap-speed
3400 pounds = 115.41 trap-speed
3200 pounds = 117.77 trap-speed
3000 pounds = 120.32 trap-speed
"Old racers" used a formula known as the "HOOK-FACTOR" to determine how effecient their cars were, multpilying the ET by the MPH:
a 'factor' of 1320 was thought to-be optimal (i.e.: the car's potential ET had been maximized via gearing and traction).
Cars that sacrificed ET for streetability/mileage by using taller gearing would have a 'factor' in the 1380/1420-range:
most 'serious' street/strip cars have a 'factor' in the 1340/1360-range (my Z28 typically goes 12.85 @ 105 for 1349+ tax).
If we use a 'factor' of '1420' (worst-case scenario), we see that
111.22 MPH = 12.76
113.54 MPH = 12.50
115.41 MPH = 12.30
117.77 MPH = 12.06
120.32 MPH = 11.80
111.22 MPH = 12.76
113.54 MPH = 12.50
115.41 MPH = 12.30
117.77 MPH = 12.06
120.32 MPH = 11.80
