Pasting and rices for powder coating
Old May 7, 2005 | 11:43 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Pasting and rices for powder coating
Okay guys I officially got my dates for deployment overseas which means when I get back in June 06 I'll have some $$$ to invest in the Vette. Things to come.
1. Dupont Mercedes black paint job
2. rebuild front suspension
Since SanDiegoPaul just got his whole front end redone I know the expense for Van Steel A-Arms so I'm thinking dropping off everything at a local shop for blasting and powder coating. After which I'll drop off everthing for pressing in the bushings. Assign a cost you know to be fair market price so I know what I'm dealing with.
(assume labor for sand blasting prior to powder coating)
a. sway bar
b. upper and lower A-arms(4) to include shafts
c. PS pulley
d. crank pulley
e. water pump pulley
f. center rod of drag link
Old May 8, 2005 | 01:52 AM
Twin_Turbo's Avatar
Twin_Turbo
I wouldn't powdercoat the pulleys or have them tape off the grooves, if you powdercoat the grooves the belts will squeel and drive you mad.
For the center link, make absolutely sure not too much powdercoating gets into the tapered holes or else you'll see yourself buying a reamer (aout 100$)
I can't comment on the prices.
Old May 8, 2005 | 08:24 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
can't help you on prices but good luck on the deployment. bob
Old May 8, 2005 | 08:38 AM
baja216's Avatar
baja216
Old May 8, 2005 | 08:57 PM
oregonsharkman's Avatar
oregonsharkman
Awwwh...I thought the title was "Pasting Ricers"....
Old May 9, 2005 | 12:21 AM
Bangkok Dean's Avatar
Bangkok Dean
Maybe be getting stationed in Japan? But we all wish him godspeed
Old May 9, 2005 | 02:01 AM
fauxrs2's Avatar
fauxrs2
Not bad advice - but its never been a problem on my pullies which were all powder coated before they went back in - look good and nary a squeal outta dem
Old May 9, 2005 | 09:30 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
check this guy out : http://www.centralmissouripowdercoating.com/ He's cheap and does 1st rate work! he did all my pieces and things look great!
To Pasting and rices for powder coating
