Clutch Fan Question
So it's not drawing power off the engine at high speed because the engine gets cooled by air at speed. Only benefit of a flex/fiberglass fan is less weight. The offset is it's noisier.
Dep
Here's a pic of one I found on the net.
Dep
Even my 75 year old uncle who a car guy told me "you know GM didn't hire a bunch of monkeys for engineers" "those guys know what they're doing son"
I was just looking for more HP's and less weight. Hey I'm a guy that's what guy's do?
Oh and the person running hot I added sub-zero from ecklers and I never run above 200*
Note that my 2004 Silverado has a pastic fan AND the fan clutch on it. So it saves weight AND HP.
Pretty cool
Dep
Fan clutches absorb nearly zero power when not required to turn the fan. It is NOT a performance upgrade to ditch them for electric fans.
That is partially, at least.Fan clutches OR clutchless flex fans at higher rpm pull little power. On the other hand, electric fans don't pull anything off of the flywheel. Energywise, anything that is pulling power only when needed is a boost to the system's efficiency. However, all the wasted power from an always-on electric fan is only from the battery, mandating the alternator be under a load more often.
I do not know how much different breaking resistance drag the alternator produces when it is actually supplying current, but I believe it is different from when it doesn't detect the need for current (i.e. I *think* it's harder to turn when the circuit is on and deriving current from it than when it does not, although I s'pose it's possible it has the same pull all the time and the generated current is just switched to not go to the system when it's not needed.)
In any event, the drag from the alternator hits the flywheel less than the drag from the fan moment to moment, but the same overall from the perspective of system energy perspective. Any difference in mechanical connections not losing some efficiency compared to electrical power generation also factors in there (either way you need the belt with a mechanical water pump.)
One serious concern I have always had on electric accessories such as fan, fuel pump and water pump is switching reliability and functionality when battery or alternator are malfunctioning. Long ago I switched to HEI ignition though, so I guess I ultimately decided screw the "works better under more broken down condition option" and risk being sidelined for a bad alternator. One day I will switch to one of the higher powered electric water pumps too.
The SPAL (and now Zirgo) fans pull 2500-4,000 cfm on their 16" premium models.
BTW, from the perspective of someone who only ever bought ancient junkers and lived in a hot climate, I always ditched the factory clutched fan, which fail when old, in favor of the best flex fan I could find and went with the lowest temp thermostat or without on engine designs that can take it (neither SBC nor BBC can run without a thermostat.) Yet with all parts new, a higher running temp and a fan clutch are good things.
I had a Haydon for three months when it exploded! I has steady cruising on the Interstate at 70mph when 3 of the blades let loose. They went right through the fan shroud like hot razors through butter-the holes they made had perfect airfoil shapes! I was lucky none flew off in the direction of the hood! Hoses and belts all sliced up. It was a mess.
Haydon examined the fan and determined it was a factory defect and treated me very very well.
But now I'm scared of them.
I have my aux fan wired up so it comes on when the a/c is on AND the break pedal is pressed (with a 20 second on-break delay). This is the surest way I thought of to allow the aux fan to run while the 'vette is either stopped or in slow speed traffic only. I didn't want it to run while cruising at speed.
It also comes on at 210F coolant temp and is manually switched as well.
The electric fan may pull a constant load but at least it does not pull a higher load at high RPMs as belt driven fan does. This is actually reverse of what the engine needs, i.e. more cooling at higher speeds. Most cooling is needed sitting at an idle with no air ram air effect.
I did see a .3 sec improvement in the 1/8 mi after removing the belt driven fan, but I also had just installed my dual air cleaners.
Based on the gauge of the wires, it doesn’t look like the fan could draw many more amps than the lights. Do you run a better time with your lights off?
Just some food for thought....
Good Points:
1. Frees up a lot of room in the engine bay.
2. They do improve fuel economy on the highyway by at least 2 mpg--my 'Vette pulls 3000rpm at 70mph--so that's a reason for the improvement.
3. Makes the car rev and drive a whole bunch smoother.
4. Quiets the mechanical underhood noise.
5. Does free up power on WOT--less spun mass.
Drawback:
1. Very high underhood temperatures--the electric fans don't blow enough air to cool anything but the radiator--everything becomes RED hot. Not good for a/c and the extended life of underhood components.
That one drawback was enough for me to go back to the fan/clutch.
Dep
I have heard people say this before, but my 'Vette can't run on the highway without the fan. I have a new 4-core radiator, Edelbrock Victor water pump, Hi-flo t-stat, new hoses, and new intake/motor. In other words, the cooling system is better than original.
And please, if there's something wrong with my 'Vette, let me know!!!
My '73 has a LT1 spec engine in it and can sit in traffic all day long at 100 degrees outside temp without overheating. The gauge will go up to around 195-200 degrees, at which time you hear the fan clutch engage (audible fan noise) and then see the temp drop back to around 185-190. The cycle repeats until the car is in motion where the fan never engages again. This car has a stock '73 radiator, fan and fan clutch.
If you need a fan running full time to avoid overheating you have a problem, never mind pretending that running an electric fan 'saves power'
