advice for a first timer on this c3
I really like the 70's C3's best, and after looking through some local trader mags and websites, I found this one:
http://kopackicars.com/carview.php?number=40
The mileage and price combination seemed appealing. I'm not quite up to speed on all the mechanics yet, so I don't want to get a vette that is always going to be up on stands. I realize that getting a later model one generally means more work and upkeep, but they are just so cool for lack of a better term.
Thanks guys. I hope to be a proud owner of... some kinda vette soon.
And, nothing is more fun to own AND drive than a C3.
Sorry, I'm kind of a newb - can you clarify what kind of other problems you mean? And what NCRS means?
Thanks!
But be aware these cars can be a challenge as a daily driver. They require much more care & feeding than modern cars -- they did when they were new! (If you owned a car in the '70s, you'll know what I'm talking about.)Anyhow, taking a low-mileage car like this and using it more frequently will cause all sorts of issues to pop up. It's not like they can't be fixed or anything like that, but you need to be aware it's gonna happen. I'm talking about things like random driveline leaks, bushings giving out, brake caliper issues...stuff like that. Not a big deal, but annoying if you're not used to it.
BTW: Around here, NCRS often stands for "Not Correctly Restored Stingray"...like mine. Officially, it stands for National Corvette Restorers Society. These are the folks who are into keeping their cars just like the day they came off the showroom floor. (Different strokes for different folks and all that...)
Good price,though.If you purchase it,drive it,inspect everything above,watch fluid levels,checking after,and before driving.Make a check list.
After I had laid mine up for several years,I replaced all hoses,fuel pump,drained gas,all fluids and replenished. That included all belts.Check tires carefully for bead cracking.
NCRS will be able to tell you about that "bolt" on the exhaust clamp that is not stock item for your vette.Heh.
NCRS=National Corvette Restoration Society
http://www.ncrs.org/
If you are after a driver, then you may want to stay away from collectable or very low-mile cars since every drive or modification will depreciate its value. You could probably find a good driver for less money too.
Keep in mind this comes from someone who wanted an inexpensive driver that I could modify without worry.
Good luck.
I don't have the knowledge or workspace to be tinkering on whatever I get every day, and that's the main thing making me apprehensive about a C3. There are several low-to-mid miles mid 90's C4s i've seen for sale... perhaps that would be a wiser choice for a first timer. I would sure miss that sweet sray body though.
You can get a six speed manual(overdrive) with fuel mileage,good power,handling.I drove one(loaner) for six months.
http://www.idavette.net/facts/93.htm
