Wanted: specific Corvette buying tips
Old May 12, 2005 | 08:16 AM
AirTrafficController's Avatar
Default Wanted: specific Corvette buying tips
I plan on buying a '70 or '71 Corvette, probably this August @ Carlisle, if not sooner. What I'm looking for is specifictips on things to look for (good and bad) on a Corvette.
        Thanks - Mark
        Old May 12, 2005 | 08:45 AM
        JB's Avatar
        JB
        St. Jude Contributor
        There's a good list at www.corvettefaq.com . Main thing to look for is rust in the windsheild supports and in the trailing arm pockets.
        JB
        Old May 12, 2005 | 05:19 PM
        Thanks JB. I will keep an eye out for those two areas. That's a nice Corvette you have
        Old May 12, 2005 | 09:22 PM
        CGGorman's Avatar
        CGGorman
        I'd suspect you'll see the highest prices in country at Carlisle, though I've never been there.
        After frame rot, paint and interior are the most expensive to repair. Glass is relatively cheap, as are most engine parts...except correct chrome valve covers and similar. Overheating is always a concern, so make sure the radiator is in good shape and that all the shrouding and seals (to prevent air bypassing the rad) are in place. Weatherstripping is a little expensive, too.
        Old May 12, 2005 | 09:38 PM
        1980 454's Avatar
        1980 454
        also check the number 2 body mounts these pockets inbehind the lower kick panel get alot of rust damage and over all this is probably a key feature to look for .removing the body to do the rocker channels can get very pricy . all it takes is a screwdriver and that there screwdriver just might save you thousands of dollars even though the rest looks good this would be a good reason to pass for this cowboy.
        Old May 12, 2005 | 09:44 PM
        gq82's Avatar
        gq82
        St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
        IMHO, Carlisle is a good place to shop for a vette.....you will see the good, the bad, and the ugly. You might want to enlist the help of a forum member (a lot of us go to Carlisle every year) or join a local Corvette club. In any event if your prepared, know what to look for and go early you might be coming home in a vette.
        Good Luck!!
        Old May 12, 2005 | 09:50 PM
        early shark's Avatar
        early shark
        AirTrafficController:
        Corvettes @ Carlisle is a great place to shop for "early shark" cars. I have owned 3 '70's, 2 '71's & 2 '72's, all coupes.
        I'm going to take a different approach and tell you about some minor differences in the 3 years that may be helpful in making your selection. 1970 interiors are brighter, especially blue, green & saddle. 1971 interiors blue, green are dark. 1970 engines are either 10:25 to 1 or 11:00 to 1 compression ratio, so fuel needs to be premium. 1971 engines are either 8:50 to 1 or 9:00 to 1 compression ratio, so fuel quality isn't as big an issue. 1970 LS-5 has monster torque at 500 ft lbs, when you stick your foot into it! 1971 LT-1 engine is a balanced engine with great road manners without the finickyness of super high compression woes.
        Old May 12, 2005 | 11:34 PM
        Sandiego70's Avatar
        Sandiego70
        Good luck, I like my 70, join the gang!
        To Wanted: specific Corvette buying tips
