72 coupe rear Defogger Info
Hi:
I would appreciate it very much if someone could forward me some pictures of their rear window defogger for a 69-73 corvette coupe? I am interested in knowing how the blower motor mounts behind the driver seat, how the grille is positioned near the rear window as well as the inside of the left rear wheel well above the left rear tire. I have the assembly manual..I hope that's not the best I can do..please say it isn't so.
Thanks- Joe
Thanks- Joe
Theres a rear window defogger???????
Now thats something that I didnt know.
I need to stay tuned to see if this is something that is installed in mine.
kdf
kdf
The blower motor gets mounted far back as it can (almost against the rear light panel) behind the left rear wheel hump. There should be an indent in the inner fender fiberglass that it fits into. Bolts on through the inner fender. A flex duct then connects the motor to the vent. The vent is even with center of the rear window, and mounted in the rear quarter trim panel. The duct is available through DocRebuild, but the vent is very hard to find. Must search for used... The AIM is your only source for instructions...
Eddie
Eddie
