tire pressure decal help please!!!
Old May 16, 2005 | 07:57 AM
texaswilkins's Avatar
texaswilkins
Default tire pressure decal help please!!!
Will one of you guys please tell me what information is on the drivers door tire pressure decal? I have an 82 but the information is the same on all I think?
Bill
Old May 16, 2005 | 08:27 AM
rihwoods's Avatar
rihwoods
Bill
MAx load (Weight/Occupants) Cold tire Pressure(Front/Rear)
Reduced Load
Tire size
Maximum Inflation Pressure
Load range B= 32 PSI
C= 36 PSI
D= 40 PSI
Note:Tire Load Range is stamped on tire
Temp Spare= P195/80D15= 32PSI
Old May 16, 2005 | 08:49 AM
texaswilkins
Can you read the information in those blocks? I should have been more specific, I bought a new decal because I couldn't read the information on mine. Now I need to fill in the blocks.
Bill
Old May 16, 2005 | 10:34 AM
rihwoods's Avatar
rihwoods
Bill
I quoted from my owners manual.Your numbers may vary from my actual sticker data,which is:
Cold tire pressure= 28 PSI front /32 PSI rear(Max load 2 people ,luggage)
Reduced load= 20 PSI front / 26 rear (2 people)
These were based on original radial tires load range.You must go by tire load range you are running now,and under no circumstances would I ever drop below 28 PSI,period. I never went by GM "reduced load" data.
To tire pressure decal help please!!!
