Wide tires for 68??
Old May 17, 2005 | 05:43 PM
chadman's Avatar
chadman
Default Wide tires for 68??
What are the widest tires that will fit without rubbing on my 15X8 TT IIs? I'm running 235/60 now but would like more rubber next time if possible.
Old May 17, 2005 | 05:47 PM
Corey_68's Avatar
Corey_68
I have 275X60X15's on stock ralleys, they fit fine even before my OS trailing arms. You may need to relocate the E-brake bracket.
Old May 17, 2005 | 06:58 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Old May 17, 2005 | 07:44 PM
wildman378's Avatar
wildman378
hey what about for a 68 with stock 7" wheels? i like 255/60's but think I might try 245/60 so they will fit the rims a little better and MAYBE that would make them not rub.
whatcha think?
Old May 19, 2005 | 01:40 PM
Jims79's Avatar
Jims79
I like the 245/60 on front & 255/60 on the rear. The 255 were to wide for the front. A friend runs 275/60 on the rear, man that's a fat tire.
Old May 19, 2005 | 02:11 PM
GrandSportC3
275's in 50 or 60 series should work fine. The backspacing on the TT2's is 3.75 which gives you 1/4 inch extra clearance to the e-brake bracket..
To Wide tires for 68??
