Light up the night
Ricers have there undercarage lights so this is kind of my version
my camera was having problems cause of how dark it was but i will try to take better ones latter
just wanted to share and see what you guys
Billy
It would be cool if you could somehow make it get brighter with higher engine rpms, have it dim at idle.
I was going to go with the mini hallogin lights that ricers use for there cars but they did not have then in red and that is what i was going for
I think it's cool as hell, and would like to do it to my car.
Alex
Alex
Good morning class and welcome to the world of LIGHTS
please follow my easy step by step directions for our task today
now before we begain i must tell you there are 2 ways of doing this... the advised way and my way
If you would like you can run throught the fire wall with all of the other wires but i find that that way requires way to much work
so here we go
first the lights are put up and the wires pulled inside from the underside
then i pulled the wires from the passenger side of the car up under the hood and ran the across to the driver side
from here i ran the wires from the passenger side and down to where the light is on the driver side. with the wires together i ran them into the cabin from under the driver side using the drain plug
after running through the drain pulg i used water tight sealent to make sure water from the road would not end up in the cab
then i ran under the carpet up to the switch on the side of the driver side. this switch is already run to the altinator and has a fuse.
and that is how i did it... i know there are better ways of doing it but for me i think this will work.
easy to do and all wires are hidden
love the bling!
