Hooker sidepipe installation question
Old May 18, 2005 | 06:07 PM
rane-dig's Avatar
rane-dig
Default Hooker sidepipe installation question
I'm installing some new hooker headers/sidepipes on my '73 along with a fresh engine, and tko600. Has anyone noticed that the header on the driver's side sits lower than the one on the passenger side? I'm comparing the difference to the frame not the body. I'm going to double check motor mounts and everything else on Friday just to make sure everything is right. What has your experience been?
Old May 18, 2005 | 06:22 PM
SharkPilot's Avatar
SharkPilot
My Hookers have been on the car for many years and they are pretty even side to side.
Could it be that you have the engine rocked toward one side just a little in the engine mounts? A small variance there makes a big difference all the way out at the header collectors.
I have seen that happen before.
Good luck,
SharkPilot
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Just crawled out from under my '72 as I am starting a front end rebuild. Gotta say on mine, the pipes to frame gap is pretty much even on both sides.
Old May 18, 2005 | 07:17 PM
SteveG75's Avatar
SteveG75
My passenger side has a litlle more clearance than my drivers. Exact tolerances weren't big with GM in the '70s.
Old May 18, 2005 | 07:23 PM
jcswm's Avatar
jcswm
i just went and looked at mine. 'bout the same on both sides here!!!
Old May 18, 2005 | 09:31 PM
Red73's Avatar
Red73
Mine are pretty even. Rod
Old May 19, 2005 | 10:18 AM
rane-dig's Avatar
rane-dig
Thanks for checking this out. I'm going to double check my mounts and make sure they are seated correctly. I'll also loosen the header and see if there is any play there.
Old May 19, 2005 | 10:26 AM
Z-man's Avatar
Z-man
Does anyone know if you are you able to install these from below after the engine is in?
Old May 19, 2005 | 10:54 AM
rosslato's Avatar
rosslato
make sure u used anti-sieze between the header and the sidepipes or it's gonna be a beetch to get em apart in the future. mine are close
Old May 19, 2005 | 10:58 AM
Mark70's Avatar
Mark70
I installed mine with the engine in. I have a 350 with a 4-speed, so I had to remove the clutch pivot arm that goes between the frame and block, and the rocker panels. Otherwise, just raise the car high enough to snake the headers in from below.....piece of cake!!
Old May 19, 2005 | 11:02 AM
SteveG75's Avatar
SteveG75
That is how I did mine. Had the frame rails about 18" off the ground. Just had remove the clutch linkage, dipstick, and plugs for clearance. Think I also had the starter off at the time as well.
Old May 19, 2005 | 04:12 PM
Z-man's Avatar
Z-man
Great -Thanks!
Old May 19, 2005 | 05:29 PM
Daytona69's Avatar
Daytona69
Mine are pretty even too
Old May 19, 2005 | 05:51 PM
SharkPilot's Avatar
SharkPilot
Yes, it is indeed possible to do. I have even removed the left side header with the side pipe still attached. The rear of the car has to be pretty high up in the air but it can be done.
I have installed two different sets of Hooker sidemounts (black and chrome) and my engine has never been removed from the frame.
All the Best,
SharkPilot
Oops... guess I should have read all the way to the bottom. Sorry for the duplication.
To Hooker sidepipe installation question
