Trans Problems!!!!!!! HELP
Old May 18, 2005 | 06:55 PM
Anubis76's Avatar
Anubis76
Default Trans Problems!!!!!!! HELP
ok so today i finally got around to changing the filter and gasket on my trans.
every thing went fine untill i filled it up and started to run it throught the grears.
for some reason it is leaking from the top edge of the pan and i cant get it to stop.
so i thought maybe the was a peace of the old gasket that i did not see right at the leak so the new gasket cant make a good seal. so i went and bought 5new qt of ATF and pulled the pan again and clean both sides (the pan and on the trans) and i inspected the gasket and there seems to be nothing wrong at all.
so then i put the pan back on and filled it back up and agian it starts to drip right from the same place
what can i do??????????
Old May 18, 2005 | 08:00 PM
PortDawg's Avatar
PortDawg
St. Jude Donor '05
Obvious question:
You did use gasket sealer and make sure to circle the bolt holes correct? Also, there is a pattern to tightening them up to make sure that you don't twist the lips. Kinda like lug nuts....
Oh and the detents on the pan are still good and not flattened too right ?
Jim
Old May 18, 2005 | 09:53 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i don't use any sealer but i do use a torque wrench....overtightening these gaskets is the kiss of death. i think my 700r4 tightening spec is 100 inch lbs.....
Old May 18, 2005 | 11:19 PM
Anubis76's Avatar
Anubis76
Thank you for those you help but the problem is fixed
you guys hit the problem right on the nose...... over tightening the bults was the problem
but new ATF and a new gasket and a tourqu rench did the job
thanks all
To Trans Problems!!!!!!! HELP
